29650 Discussions
Compiler error#8299 when recompiling in version 11.1
Reinaldo_Garcia
I have a program that was compiling and runing fine in version 11.0.074. When I upgrad to version 11.1, the same code gives me this error in the CALL DDDATA(LOC(OpCodes)) in subrotine SetDDData (see below):
"error #8299: A scalar actual argument must be passed to a scalar dummy argument unless the actual argument is of type character or is an element of an array that is neither assumed shape nor pointer. [IPTR]"
I checked the compiler options and seem to be the same for both versions.
Any suggestions?
Reinaldo
SUBROUTINE SetDDData (WindowHeader)
use spmodule ! Specifies constants, TYPEs and OpCodes
USE GLOBALSHAL2D
TYPE(SIMPLE_WINDOWS_DATA_STRUCT_T), DIMENSION(3) :: OpCodes
CHARACTER(50) :: WindowHeader
TYPE(SIMPLE_WINDOWS_SIZE_T) WindowSize
SAVE OpCodes,WindowSize
WindowSize%iUnits = SIMPLE_PERCENT
WindowSize%iWidth = 80
WindowSize%iHeight =
WindowSize%iDepth =
OpCodes(1)%iOpc = SIMPLE_WINDOWS_SET_WINDOWNAME
OpCodes(1)%iPtr = LOC(WindowHeader)
OpCodes(2)%iOpc = SIMPLE_WINDOWS_WINDOW_SIZE
OpCodes(2)%iPtr = LOC(WindowSize)
OpCodes(3)%iOpc = SIMPLE_WINDOWS_END_LIST
CALL DDDATA(LOC(OpCodes)) ! here is the compile error
CALL DEVNAM('WINDOW')
END SUBROUTINE SetDDData
MODULE SPMODULE
TYPE SIMPLE_WINDOWS_DATA_STRUCT_T
INTEGER :: iOpc
INTEGER :: iPtr
END TYPE SIMPLE_WINDOWS_DATA_STRUCT_T
SUBROUTINE DDDATA(IPTR)
!DEC$ ATTRIBUTES STDCALL, REFERENCE, MIXED_STR_LEN_ARG, DECORATE, ALIAS:"DDDATA" :: DDDATA
INTEGER, DIMENSION(*), INTENT(IN) :: IPTR ! 1D[8]
END SUBROUTINE
The compiler is now detecting an error in your code that it didn't previously. This is discussed in a recent Doctor Fortran post, I've Come Here For An Argument. The problem is that you're passing the scalar expression LOC(OpCodes) to IPTR which is declared as an array. Read the post for more information.
Reinaldo_Garcia
Steve:
Thanks so much for the clarification.
Reinaldo
