29353 Discussions
Compiler error allocating a member variable of a recursive derived type with source or mold
Victor_S_2
Deal Intel Fortran Compiler Support team,
I'm getting a compiler error while allocating with mold a member variable of a recursive derived type. Is this legal or I'm committing some mistake?
The error message I get is the following one:
ifort-test.f90(30): error #8152: Neither the ERRMSG= variable nor any part of the source expression in SOURCE= or MOLD= specifiers may be allocated in the ALLOCATE statement in which it appears.   [MY_OBJECT]
        allocate(this%next_level%my_object, mold=this%my_object, stat=error)
I can reproduce this with the code snippet below.
Thanks in advance,
Víctor.
module my_module
implicit none
private
    type :: object_t
    end type
    type, extends(object_t) :: object1_t
    end type
    type, extends(object_t) :: object2_t
    end type
    type :: level_t
    private
        class(object_t), allocatable :: my_object
        type(level_t), pointer :: next_level
    contains
    private
        procedure :: allocate_next_level
    end type
contains
    subroutine allocate_next_level(this)
        class(level_t), intent(inout) :: this
        integer                       :: error
        allocate(this%next_level, stat=error)
        allocate(this%next_level%my_object, mold=this%my_object, stat=error) ! <- error occurs in this line
    end subroutine
end module my_module
Thanks - this is very similar to a problem we fixed a few years ago, but not quite the same. Escalated as issue DPD200415804.
