29648 Discussions
Compiler error reading namelist in a subroutine
filippo_ge
I'm using version 8.0 of the Intel Fortran Compiler on a PIII PC with a fully updated RedHat 9 operating system installed.
Apparently the compiler is unable to go through
this simple piece of code because of the namelist
reading in the subroutine read_namelist:
Program test
character (len=60):: title
Namelist /biatch/title
call read_namelist
write(6,*) title
Contains
Subroutine read_namelist
Open(unit=12,file='data.input',status='old')
read(12,biatch)
Close(unit=12)
End Subroutine read_namelist
End Program test
The compiler crashes with the message:
fortcom: Severe: test.f90, line 13:**Internal compiler error: segmentation violation signal raised**
I had no problems with version 7 and other fortran compilers
(e.g. nag 4.2 and Compaq Fortran V5.5). Any ideas?
Filippo
I've heard of this problem before. Are you running a reasonably current version of the compiler? It compiles ok in the version I have on my system, though that's a bit newer than what's been released. Do try it with 8.0.044 or later.
filippo_ge
At the moment I'm running the l_fc_p_8.0.034
version of the compiler which seems to be the
latest one available for non-commercial use.
I suppose I have to wait a little while for
a new version being released.
Filippo
