Compiler error shape mismatch
zekebryant
I have a shape mismatch error for ITD. Not sure why can someone please help identify the mismatch.
SUBROUTINE NET (TD, ITD, N, T, Q)
DIMENSION TD (601), ITD (1552), T (N), Q (N)
CALL NETEET (N, ITD, ITD (2), T, TD, TD (101), TD (601), ITD (3), &
ITD (53), ITD (553), ITD (1053), Q)
RETURN
END SUBROUTINE NET
SUBROUTINE NETEET (N, M, NT, T, G, TRM, HTC, KX, INDX, II, JJ, Q)
DIMENSION T (M), G (100), TRM (500), HTC (100), KX (50), INDX (500), II (500), JJ (500), Q (M)
COMMON DUM (800), QD (100)
Anonymous66
Valued Contributor I
The issue is likely your call to NETEET in NET. You are passing the array ITD in as the value of M which appears to be a scalar based on how you are using it.
RETURN
END SUBROUTINE NET
zekebryant
ITD is defined in a COMMON Block in the main program
COMMON / THERM2 / ITD (1552), IGBP (20, 5), ITP (15, 5)
There are a few calls that other functions that pass ITD
If I DIMENSION ITD(1) in these functions will it become a scalar in those functions
zekebryant
mecej4
What Annalee is pointing out as the error can be fixed by your changing
to
CALL NETEET (N, ITD(1), ITD (2), T, TD, TD (101), TD (601), ITD (3), &
This will work correctly if the intended value of M has been set into ITD(1). As far as code generation is concerned, the object code is probably going to be the same whether ITD or ITD(1) is used as the second argument, since both have the same address.
Whether ITD is in a common block or not in some other subroutine is not relevant.
The problem with compiling old programs with interface checking turned on is that you will often see complaints such as this, which you obviously do not like to spring up, as well as warnings about other shady practices that will one day give an unpleasant surprise.
Anonymous66
No, a 1 element array is not the same as a scalar.
zekebryant
Thanks for thefeedback. I am in the process of updating old Fortan 66 and 77 code. I using your complier to identify all of the issues and hopeful resolve them. I was able to work pass this error with your help.
zekebryant
I looking for some advice for the best practice to help resolve the following code error. This code is being converted from .FOR to f90.
The following is code in question:
CALL TEMPIN (TITLE, NBRG, ITEMP, IPUNCH, IUB, ITD, N, T, ITP, TB, &
TD, IGBP, BCP, TD, ITD, IT1, EP1, IT2, EP2, START, STEPIN, STOP, &
TTIME, BTIME, VDC, TMAX, BD)
SUBROUTINE TEMPIN (TITLE, NBRG, ITEMP, IPUNCH, IUB, M, N, T, ITP, &
TB, G, IGBP, BCP, TD, ITD, IT1, EP1, IT2, EP2, START, STEPIN, &
STOP, TTIME, BTIME, VDC, TMAX, BD)
!INTEGER(2) SSQMSF
CHARACTER(1) LIST
CHARACTER(48) MESSAGE
COMMON / CONGHT / GCONS (100), IGCONS (100)
COMMON / UNITS / IMET
COMMON / LSTDAT / LIST (80), KTEST
COMMON / LSTMES / MESSAGE
! IMET=0 ==> ENGLISH UNIT INPUT
! IMET=1 ==> METRIC UNIT INPUT
! $LARGE:TEXT
DIMENSION TITLE (47), T (M), ITP (15, 5), TB (15, 5), G (M), &
IGBP (20, 5), BCP (4, 8, 5), TD (690), ITD (1552), VDC (N), &
TEXT (25), IDU (5), DU (5), BD (1830, 5)
M in TEMPIN is problem error #6634 shape matching rule
What is the best procedure to correct the problem is the question.
How is ITD declared in the caller?
zekebryant
Here is the definition
mecej4
So, ITD is an array containing 1552 integers. One of these, presumably ITD(1), is supposed to be equal to the desired value of M, the sixth formal argument of the subroutine.
Verify that the value of M is placed into ITD(1) before the CALL, and replace the actual argument ITD by ITD(1), as I suggested in #4.
I doubt that more concrete recommendations can be given since we cannot reach back in time and deduce what the author intended to be done with these lines of code.
zekebryant
I followed the procedure, but when I try to use T(M) for example:
! ... THE TEMPERATURES WILL BE CALCULATED
100 DO 105 I = 1, M
T (I) = TEMP
run time error is generated. When I dug the code T has no array length even thoughthe value of M is 3D.
This why I ask the additional question. Please adivce on what I do not understand. Below is the entire routine.
!INTEGER(2) SSQMSF
CHARACTER(1) LIST
! $LARGE:TEXT
DATA TEXT / 'COND', 'UCTI', 'ON ', ' ', ' ', 'FREE', ' CON'&
&, 'VECT', 'ION ', ' ', 'FORC', 'ED C', 'ONVE', 'CTIO', 'N ', &
&'RADI', 'ATIO', 'N ', 2 * ' ', 'FLUI', 'D FL', 'OW ', 2 * ' &
IN = 5
KUT = 6
! CHECK FOR PRESENCE OF HARDWARE LOCK
!KSUM = SSQMSF (LIST)
IF (KSUM.NE.KTEST) THEN
WRITE ( *, * ) MESSAGE
! STOP
ENDIF
! SET TEMPERATURE CONVERSION FACTORS
C1 = 1.8
C2 = 32.0
DO 1 I = 1, 100
GCONS (I) = 0.
IGCONS (I) = 0
1 END DO
DO 5 I = 1, 20
DO 5 J = 1, 5
IGBP (I, J) = 0
IF (I.LE.15) ITP (I, J) = 0
IF (I.LE.15) TB (I, J) = 0.0
5 CONTINUE
! ... READ CONTROLLING CARD AND SET SOME VARIABLES
READ (IN, 10) M, N, TEMP, IPUNCH, IUB, IT1, EP1, IT2, EP2, START, &
STOP, STEPIN, TTIME, BTIME, TMAX
10 FORMAT(2I5, F5.0, 3I5, F5.0, I5, 7F5.0 )
IF (ABS (TMAX) .LT.1.E-30.AND.IMET.EQ.1) TMAX = 600.
IF (ABS (TMAX) .LT.1.E-30.AND.IMET.EQ.0) TMAX = 600. * C1 + C2
IF (EP1.LE.0.0.AND.IMET.EQ.1) EP1 = 2.0
IF (EP1.LE.0.0.AND.IMET.EQ.0) EP1 = 2.0 * C1
ITEMP = 1
IF (M.EQ.0) ITEMP = 0
IF (ABS (STOP - START) .GT.0) ITEMP = 2
IF (M.GT.0) WRITE (KUT, 15) TITLE
15 FORMAT('1'////' ',27A4/'0', 20A4)
! ... STEADY STATE
IF (ITEMP.NE.1) GOTO 28
WRITE (KUT, 20) IT1, EP1
20 FORMAT('0STEADY STATE TEMPERATURE CALCULATION. ITERATION LIMIT', &
& I4,', ABSOLUTE ACCURACY', F6.2, ' DEGREES')
IF (IUB.NE.0) WRITE (KUT, 25)
25 FORMAT(' ', 5X, 'INTERMEDIATE OUTPUT WILL BE OBTAINED')
! ... TRANSIENT
28 IF (ITEMP.NE.2) GOTO 35
WRITE (KUT, 30) START, STOP, TTIME, BTIME, TMAX
30 FORMAT('0TRANSIENT TEMPERATURE CALCULATION, BEGINNING AT TIME', &
& F7.1, ' SECONDS, ENDING AT TIME', F7.1, ' SECONDS.'/ &
& ' ', 5X, 'TEMPERATURE OUTPUT INTERVAL', F7.1,' BEARING CALCULA',&
& 'TION INTERVAL',F7.1, ' MAXIMUM ALLOWABLE TEMPERATURE', F7.1 )
IF (IUB.NE.0) WRITE (KUT, 32)
32 FORMAT(' ', 5X, 'BEARING OUTPUT WILL BE OBTAINED AFTER EACH', &
& ' BEARING CALCULATION')
35 IF (IMET.EQ.1) WRITE (KUT, 40)
IF (IMET.EQ.0) WRITE (KUT, 41)
40 FORMAT('0UNLESS OTHERWISE STATED, INTERNATIONAL UNITS ARE USED'//)
41 FORMAT('0UNLESS OTHERWISE STATED, ENGLISH UNITS ARE USED'//)
! FOR IMET=0, CONVERT VALUES OF TEMP, EP1, AND TMAX TO METRIC.
IF (IMET.EQ.1) GOTO 45
EP1 = EP1 / C1
TMAX = (TMAX - C2) / C1
45 CONTINUE
IF (NBRG.EQ.0) GOTO 100
IF (ITEMP.NE.0) GOTO 100
! ... READ AND WRITE INITIAL BEARING TEMPERATURES
DO 65 I = 1, NBRG
READ (IN, 60) (TB (J, I), J = 1, 15)
60 FORMAT (16F5.0)
65 END DO
WRITE (KUT, 70)
70 FORMAT('0GIVEN TEMPERATURES')
WRITE (KUT, 75)
75 FORMAT('0',5X,'BRG O.RACE I.RACE BULK OIL FLNG.1 FLNG.2 FLN&
&G.3 FLNG.4 CAGE SHAFT I.RING ROLL.EL. O.RING HSG.')
DO 80 I = 1, NBRG
WRITE (KUT, 85) I, (TB (J, I), J = 1, 13)
80 END DO
85 FORMAT (' ', 5X, I2, 2X, 7( F8.2,1X,F8.2 ))
IF (IMET.EQ.1) GOTO 95
! CONVERT BEARING TEMPERATURES TO DEGREES C IF IMET=0.
DO 90 I = 1, NBRG
DO 90 J = 1, 13
TB (J, I) = (TB (J, I) - C2) / C1
90 CONTINUE
95 CONTINUE
RETURN
100 DO 105 I = 1, M
T (I) = TEMP
105 G (I) = 0.
! ... READ INITIAL TEMPERATURES (AND NODES) NOT EQUAL TO TEMP
CALL INDUM (T, J)
IF (NBRG.EQ.0) GOTO 180
! ... READ AND WRITE BEARING TEMPERATURE NODE POINTERS
DO 120 I = 1, NBRG
READ (IN, 118) (ITP (J, I), J = 1, 13)
118 FORMAT (16I5)
120 END DO
WRITE (KUT, 125)
125 FORMAT('0NODE POINTERS')
WRITE (KUT, 75)
DO 130 I = 1, NBRG
130 WRITE (KUT, 135) I, (ITP (J, I), J = 1, 13)
135 FORMAT (' ',5X, I2, 7( I8,1X,I8 ))
! ... READ AND WRITE BEARING GENERATED HEAT POINTERS
119 FORMAT(10I5)
DO 150 I = 1, NBRG
LIM = 18
IF (BD (1, I) .LT.0.) LIM = 10
READ (IN, 119) (IGBP (J, I), J = 1, LIM)
150 END DO
WRITE (KUT, 155)
155 FORMAT(/'0NODES WHERE BEARING HEAT IS GENERATED'/'0', 5X, &
& 'BRG',2X,'OUTER RACE INNER RACE R.E.DRAG CAGE-R.E. CAGE-&
&LAND FLNG.1-RE FLNG.2-RE FLNG.3-RE FLNG.4-RE' )
DO 160 I = 1, NBRG
160 WRITE (KUT, 165) I, (IGBP (J, I), J = 1, 18)
165 FORMAT (6X, I2, 18I6 )
! ... READ AND WRITE CONSTANT GENERATED HEATS
180 CALL INDUM (G, IG)
IF (IG.LE.0) GOTO 191
WRITE (KUT, 185)
185 FORMAT(/'0CONSTANT GENERATED HEATS'//'0', 5X, 5(5X,'NODE GEN. HEA&
&T') / )
NGH = 0
KOUNTR = 0
DO 190 I = 1, N
IF (G (I) .EQ.0.) GOTO 186
KOUNTR = KOUNTR + 1
GCONS (KOUNTR) = G (I)
IGCONS (KOUNTR) = I
NGH = NGH + 1
IDU (NGH) = I
DU (NGH) = G (I)
186 IF (NGH.EQ.5.OR.I.EQ.N) WRITE (KUT, 188) (IDU (J), DU (J), &
J = 1, NGH)
188 FORMAT (' ', 4X, 5(I10, F10.2) )
IF (NGH.EQ.5) NGH = 0
190 END DO
191 CONTINUE
IF (IMET.EQ.1) GOTO 198
! FOR IMET=0, CONVERT TEMPERATURE ARRAY (T) AND GENERATED HEAT
! ARRAYS (G & GCONS) TO METRIC UNITS (DEG. C & WATTS).
DO 195 I = 1, M
T (I) = (T (I) - C2) / C1
195 END DO
DO 196 I = 1, N
G (I) = G (I) * 0.29301
GCONS (I) = GCONS (I) * 0.29301
196 END DO
198 CONTINUE
! ... READ AND WRITE HEAT TRANSFER COEFFICIENTS
200 CALL RWHTC (TITLE, TEXT, ITD (3), TD (601) )
! ... READ AND WRITE GEOMETRY CARDS
CALL RWG (TITLE, TEXT, ITD (3), TD (601), BCP, TD (101), ITD (53),&
ITD (553), ITD (1053), ITD (2) )
IF (ITEMP.NE.2) GOTO 250
! ... READ AND WRITE HEAT CAPACITY CARDS
CALL RWHC (TITLE, N, VDC)
! ... PRINT FIRST TEMPERATURE MAP
250 CALL TMAP (TITLE, ITEMP, M, N, 0, START, T)
RETURN
END
You have not shown us the error message. I do not know what you mean by "the value of M is 3D". Perhaps you could add a:
PRINT *, M
just before the DO loop so you can see what the value is. But you may not have passed array T correctly.
It is hard to help based on pieces of the program, with so much that we cannot see.
