29647 Discussions
Compiler error with function pointer as component
jmcfarland101
I'm having trouble compiling some code that uses function pointers as derived type components. I'm getting a "Code 3" compiler error. I'm able to recreate the problem withthe simple 16 line test codebelow -- the test program compiles fine with g95. (I didn't specify interfaces for the procedure pointers, as when I start doing that I run into a different compiler error, which I believe has already been discussed on this forum).
This is my first post, so let me know if I need to provide more information.
[cpp]PROGRAM farg
  TYPE container
    PROCEDURE(), POINTER, nopass :: f
    PROCEDURE(), POINTER, nopass :: g
  END TYPE container
  PRINT*, 'Running program that does nothing'
CONTAINS
  SUBROUTINE setf(cont, func)
    TYPE(container) :: cont
    PROCEDURE(), POINTER :: func
    func => cont%f
  END SUBROUTINE setf
END PROGRAM farg[/cpp]
Welcome to the forum and thanks for the bug report. I can reproduce this and will pass it on to the developers. Our issue number is DPD200110430.
