Compiler fortran Error cfx5mkext -64bit
Hich_C_
i have try to write this programm but don´t work i become errors i have no idea please i need a help. i would like to calculate CD
#include "cfx5ext.h"
dllexport(drag_factor)
      SUBROUTINE drag_factor (NLOC,NRET,NARG,RET,ARG,CRESLT,
     &                              CZ,DZ,IZ,LZ,RZ)
CC
CC --------------------
CC        Input
CC
CC  NRET   - number of components in result
CC  NARG   - number of arguments in call
CC  ARG() - (NARG) argument values
CC
CC      Modified
CC
CC  Stacks possibly.
CC
CC        Output
CC
CC  RET()  - (NRET) return values
CC
CC       Details
CC
CC======================================================================
C
C ------------------------------
C     Preprocessor includes
C
C        Global Parameters
C
C        Argument list
C
      INTEGER NLOC,NARG,NRET
C
      REAL ARG(NLOC,NARG), RET(NLOC,NRET)
C
      CHARACTER CRESLT*(*)
C
      INTEGER IZ(*)
      CHARACTER CZ(*)*(1)
      DOUBLE PRECISION DZ(*)
      LOGICAL LZ(*)
      REAL RZ(*)
C
C        External routines
C
C        Local Parameters
C
C        Local Variables
C
C        Stack pointers
C
C=======================================================================
C
C    Executable Statements
C
C
C     Argument variables stack:
C     Particle Reynolds Number          :     RE_PT      = ARG(1,1)
C     Mean Particle Diameter            :     d_p        = ARG(1,2)
C     Turbulence Eddy Dissipation       :     psy        = ARG(1,3)
C     Dynamic Viscosity                 :     ny         = ARG(1,4)
C     Density                           :     rho        = ARG(1,5)
C
C     Return variables stack            :
C     drag factor coefficient           :     CD         = RET(1,1)
C
C
C-----------------------------------------------------------------------
C     Calculate the momentum source and source term coefficient
C
      CALL USER_CD(RET(1,1),ARG(1,1),ARG(1,2),ARG(1,3),ARG(1,4),ARG(1,5))
      END
C
      SUBROUTINE USER_CD(CD,RE_PT,d_p,psy,ny,rho)
C
C
C
#include "cfd_sysdep.h"
#include "cfd_constants.h"
C
C        Argument list
C
      REAL CD, RE_PT, d_p, psy, ny, rho
C
C        Local variables
C
      REAL CD0, lambda
C
C---- Calculate Brucato Model
C
      IF (RE_PT .LT. 1.) THEN
      CD0 = 22.73/RE_PT + 0.0903/RE_PT + 3.69
      lambda = (((ny/rho)**3)/psy)**(1/4)
      CD = CD0 + CD0*(0.000867*(d_p / lambda)**3)
      ELSEIF ((RE_PT .LT. 10.).and.(RE_PT .GT. 1.)) THEN
      CD0 = 29.167/RE_PT - 3.889/RE_PT + 1.222
      ELSEIF ((RE_PT .LT. 100.).and.(RE_PT .GT. 10.)) THEN
      CD0 = 46.5/RE_PT - 116.67/RE_PT + 0.6167
      ELSEIF ((RE_PT .LT. 1000.).and.(RE_PT .GT. 100.)) THEN
      CD0 = 98.33/RE_PT - 2778/RE_PT + 0.3644
      ELSEIF ((RE_PT .LT. 5000.).and.(RE_PT .GT. 1000.)) THEN
      CD0 = 148.62/RE_PT - 47500/RE_PT + 0.357
      ELSEIF ((RE_PT .GT. 5000.) THEN
      CD0 = - 490.546/RE_PT + 578700/RE_PT + 0.46
      END IF
C
      END
TimP
You'll need to do your own proofreading as you have reformatted what you posted. F77 fixed format is strict about ignoring what falls beyond column 72.  Another glaring problem is your use of  expression (1/4) which evaluates to 0 where you may have intended 0.25 or 1./4.
mecej4
In addition to what Tim wrote, which I second, please note:
  • It is not helpful when you post text in the form of an image (.jpg, .png, etc.). Post text as straight text so that commands, error messages, etc. in your post can be copied and used as necessary. Images contain very little easily transferable information.
  • Do not post any but the shortest of program source in-line. As Tim pointed out, they can be reformatted by the forum software and have their validity/meaning completely changed. This admonition is even more important when you ask for help on an error message resulting from an attempt to compile the code. Use the {code} button on the toolbar, or attach a zipped collection of source codes.
  • If your program has INCLUDE statements/directives, usually you need to post the contents of the included files, as well.
  • Tim noted that your program uses "(1/4)" as an exponent quite often. In Fortan, that expression evaluates to zero. Along the same lines, note that your subroutine code fails to do anything useful if Re_Pt has one of the transition values 10, 100, 1000 or 5000. These values "fall through the cracks in the floor" of the subroutine.
  • The calculation of lambda is needlessly repeated six times. One instance of that preceding the cascade of IF..THEN..ELSEIF...ENDIF would suffice. Similarly, one instance of calculation CD from CD0, placed after the cascade of IF..ENDIF statements, should suffice. Unnecessary repetitions make the code more error prone and, often, result in less efficient compiled code.
Hich_C_
Hallo,
firstly thank you for helping me.
1. @Tim: i not understand what you mean "F77 fixed format is strict about ignoring what falls beyond column 72."
2. I have try to do your every instruction
dllexport(drag)
      SUBROUTINE drag (NLOC,NRET,NARG,RET,ARG,CRESLT,
     &                              CZ,DZ,IZ,LZ,RZ)
CC
CC        Input
CC
CC
CC      Modified
CC
CC  Stacks possibly.
CC
CC        Output
CC
CC
CC       Details
CC
C
C
C        Global Parameters
C
C        Argument list
C
C
C
C
      INTEGER IZ(*)
      CHARACTER CZ(*)*(1)
      LOGICAL LZ(*)
      REAL RZ(*)
C
C        External routines
C
C        Local Parameters
C
C        Local Variables
C
C        Stack pointers
C
C
C
C
C
C
C
C
      END
C
C
C
C
C
C        Argument list
C
C
C        Local variables
C
      REAL CD_o, l_o
C
C    Executable statements
C
C---- lamda calculation
C
            l_o = (((ny/rho)**3)/psy)**0.25
C
C---- Calculate mursi model
C
      CD_o = 22.73/RE_PT + 0.0903/RE_PT + 3.69
      CD_o = 29.167/RE_PT - 3.889/RE_PT + 1.222
      CD_o = 46.5/RE_PT - 116.67/RE_PT + 0.6167
      CD_o = 98.33/RE_PT - 2778/RE_PT + 0.3644
      CD_o = 148.62/RE_PT - 47500/RE_PT + 0.357
      ELSE
      CD_o = -490.546/RE_PT + 578700/RE_PT + 0.46
      ENDIF
C
C
CD = CD_o + CD_o*(0.000867*(d_p / l_o)**3)
c
      END
3. now i have just one error -:) i use cfx5mkext -64bit  to compile drag.F i receive
C:\Users\Home\.cfx\model>cfx5mkext -64bit drag.F
C:\Program Files (x86)\Intel\Composer XE 2015\bin\intel64\ifort -Qvec- -iface:cv
f -MD -fpp -include:"C:\Program Files\ANSYS Inc\v150\CFX\include" -object:winnt-
amd64\\drag.o -c drag.F
Intel(R) Visual Fortran Intel(R) 64 Compiler XE for applications running on Inte
l(R) 64, Version 15.0.4.221 Build 20150407
Copyright (C) 1985-2015 Intel Corporation.  All rights reserved.
ifort: NOTE: The evaluation period for this product ends on 21-aug-2015 UTC.
drag.F(98): error #5082: Syntax error, found END-OF-STATEMENT when expecting one
 of: ) :: , :
compilation aborted for drag.F (code 1)
An error has occurred in cfx5mkext:
C:\Program Files (x86)\Intel\Composer XE 2015\bin\intel64\ifort exited with
return code 1.
I wish you a good weekend
best regards
Hicham
mecej4
Look at Line-98. It is too long; the ')' in column-73 is ignored by the compiler, and the truncated line has a syntax error. Break the line before that position, and continue the rest of the line on a continuation line.
You did not provide the source codes for the included files.
Hich_C_
i have break the line
dllexport(drag)
     &                              CZ,DZ,IZ,LZ,RZ)
CC
CC        Input
CC
CC
CC      Modified
CC
CC  Stacks possibly.
CC
CC        Output
CC
CC
CC       Details
CC
C
C
C        Global Parameters
C
C        Argument list
C
C
C
C
      INTEGER IZ(*)
      CHARACTER CZ(*)*(1)
      LOGICAL LZ(*)
      REAL RZ(*)
C
C        External routines
C
C        Local Parameters
C
C        Local Variables
C
C        Stack pointers
C
C
C
C
C
C
C
C
      & ARG(1,3),ARG(1,4),ARG(1,5))
      END
C
C
C
C     Preprocessor includes C:\Users\Home\.cfx\model
C
C
C        Argument list
C
C
C        Local variables
C
      REAL CD_o, l_o
C
C
C
C
C
      ELSE
      ENDIF
C
C
c
      END
and provide the source but i get errors
 of: ( * ) :: , <IDENTIFIER> <CHAR_CON_KIND_PARAM> <CHAR_NAM_KIND_PARAM> <CHARAC
TER_CONSTANT> ...
drag.F(99): error #5276: Unbalanced parentheses
drag.F(99): error #5082: Syntax error, found '&' when expecting one of: <LABEL>
<END-OF-STATEMENT> ; BLOCK PROGRAM BLOCKDATA MODULE INTEGER REAL COMPLEX ...
drag.F(99): error #5082: Syntax error, found ')' when expecting one of: , <END-O
F-STATEMENT> ;
drag.F(99): error #6252: This format specifier is invalid.   [(1,3)]
drag.F(99): error #6514: A substring must be of type CHARACTER.   [ARG]
fortcom: Fatal: There has been an internal compiler error (C0000005).
return code 1.
Hich_C_
i have find the problem now it work. Thank you very much!
best regards,
Hicham
mecej4
Good, but the corrected code still has the following error that I pointed out in #2: it fails to do anything useful if Re_Pt has one of the transition values 10, 100, 1000 or 5000. All these numbers are exactly representable in 32-bit or 64-bit IEEE floating point format, so one of these constants may test as equal to an input Re_Pt having one of these values.
Line-1 of #7 probably has six leading blanks that got stripped out by the slightly ignorant forum software.
Hich_C_
oh yes i forget to change LT to LE and GT to GE
Steven_L_Intel1
That internal compiler error is a problem. It is triggered by the & continuation character for the CALL being in column 7 instead of 6. I will report this to the developers.
Steven_L_Intel1
The internal compiler error has been fixed for a future major release.
