29348 Discussions
Compiler not generateing/honoring C$OMP PARALLEL DO codes
nightcom26
I inherit a fortran code that has 2 openmp parallel do declarations. When I compile the code in Release mode, the compiler will tell me that both openmp defined loops are parallelized. However, when I compile the code in Debug mode, the compiler will only tell me that code is compile successfully. If I remove pieces of code in the parallel do region, I can sometime get 1 or both openmp region parallelize under Debug mode.
Under what condition will Fortran compiler not generating Openmp code?
I am using IVF 11.074 and VS2005 SP1.
Thanks you
jimdempseyatthecove
Check the project properties for the Debug configuration to ensure it is enabling OpenMP.
nightcom26
Both debug and release have OpenMP enabled.
the problem I have is that by removing pieces of code within inparallel region, I can sometimes get the compiler to compiler code with OpenMP statements.
jimdempseyatthecove
Is the section of code in the parallel region such that optimizations can eliminate the code completely? (assuming optimizations are enabled and the entire region appears as "dead code").
Also, insert a diagnostic write(*,*) omp_get_thread_num()
nightcom26
The openmp problem shows up in debug mode, not in release mode, so there shouldn't be any optimization done to the code. Essentially, in debug code, the code is compiled as if openmp statement does not exist.
Quoting - jimdempseyatthecove
nightcom26
I solved the problem by trying the evaluation copy of the latest Intel Fortran compiler. I guess it was a compiler related problem. Time to upgrade.
