29582 Discussions
doing a recursive function, can't seem to return an integer
javert8817
I have the following code, but it is only returning a real. Even though in the function (in this case, fib_result is integer 8, when it gets back to the main program it a bizarre real #. How can i return an integer?
RECURSIVE FUNCTION FIB (n) RESULT (fib_result)
INTEGER :: fib_result
If (n <= 2) then
fib_result = 1
else
fib_result = FIB(n-1) + FIB (n -2)
endif
END FUNCTION
PROGRAM FibRepeat
REAL :: elapsed_time, start, finish
INTEGER :: num, theresult
num = 6
write (6,11) "Final fibonacci value for input of ", num ," is ", FIB(num)
11 FORMAT (1x, A40, 2X, I3, 2x, A4, I9)
END PROGRAM FibRepeat
You need to declare FIB as INTEGER in the main program. Implicitly, it is REAL because the name starts with F (A-H, O-Z). Since FIB is not a contained procedure nor from a module, the compiler doesn't know that you wrote it as INTEGER.
FWIW, if you built this in Intel Visual Fortran in Visual Studio, you should have seen:
t.f90(33): error #7977: The type of the function reference does not match the type of the function definition. [FIB]
gib
New Contributor II
Also you should really declare argument n in FIB(n) as integer.
