Compiler possibly misses detecting an error in clause of an IF statement
avinashs
I accidentally made an error in an IF statement by writing IF (I > 0 .AND. J > K > L > 0) THEN. I presume this statement is syntactically wrong besides not being what I intended. It should have been IF (I > 0 .AND. J > K .AND. L > 0) THEN. However, the compiler and linker does not flag it as an error. Luckily I caught it before the library was updated since it represents a flaw in the intended logic of the code. Is the first statement erroneous?
program main
  integer :: i, j, k, l
  i = 1
  j = 5
  k = 4
  l = 2
  ! statement below was intended to be: if (i > 0 .and. j > k .and. l > 0) then
  if (i > 0 .and. j > k > l > 0) then
     print *, 'condition satisfied'
  end if
  read *
end program main
1>------ Build started: Project: TestFINAL_IVFForum, Configuration: Debug Win32 ------
1>Compiling with Intel(R) Visual Fortran Compiler 19.0.1.144 [IA-32]...
1>test_logical.f90
1>Linking...
1>Embedding manifest...
1>
1>Build log written to
jimdempseyatthecove
From: IVF document Data Type of Numeric Expressions
Integer operations: Integer operations are performed only on integer operands. (Logical entities used in a numeric context are treated as integers.)
edit And from Logical Expressions:
Logical operations on integers produce single values of integer type.
This would explain no error message, but is of little help in defining what order or what to expect.
Jim Dempsey
jimdempseyatthecove
The compiler may be free to evaluate
as
(i > 0 .and. (j > (k >( l > 0))))
or
(i > 0 .and. (((j > k) > l) > 0))
or
(i > 0 .and. ((j > k) > (l > 0)))
o
(i > 0 .and. (j > (k > l)) > 0)
or
(i > 0 .and. j > ((k > l) > 0))
I think I have all permutations
Jim Dempsey
Steve_Lionel
D:\Projects>ifort /stand t.f90
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.0.1.144 Build 20181018
Copyright (C) 1985-2018 Intel Corporation.  All rights reserved.
t.f90(8): warning #6192: Fortran 2008 does not allow this data type conversion.
You'd have to look at the documentation for precedence order to see how it is interpreted.
