Compiler version 2023.2.1
netphilou31
New Contributor III
I installed the latest version of OneAPI products (2023.2.1 basic and HPC kits, including critical updates except for DPC++ that I am not using) and I am noticing that for the configuration Release x64, the link process takes now a lot of time, and the "Embedding manifest" step takes even more! (tens of seconds). Is there something I missed?
My config: VS 2022 - 17.4.4, intel compiler 2023.2
Steve_Lionel
I'll comment that the "embedding manifest" step involves rewriting an EXE, and some antivirus software treats this as suspicious and may subject it to extra scanning.
andrew_4619
FYI I am using 2023.2 in vs2022 and don't have that problem.
Steve_Lionel
netphilou31
New Contributor III
Hi Steve,
Thanks for your comment, this might be the explanation since our antivirus software (bit defender) is generally a bit too agressive (I have frequently issues for dlls I built, it treats some of them as malware).
netphilou31
New Contributor III
Hi Steve,
After removing some folders (where my projects and files are generated) from the antivirus scan, the problem vanished.
jimdempseyatthecove
Try disabling multi-file IP optimization between file (/Qipon)
Jim Dempsey
netphilou31
New Contributor III
Thanks Jim for the advice, but this option is not enabled in any of my projects.
