Compiler warning #6075
Frederik_Vandenberg
When I compile thecode
integer fhandle, nlines, ncols
lstat = SetConsoleCursorPosition(fhandle, wpos)
integer(kind=4) rval, ii, event
call ZeroMemory(loc(sinfo),ii)
I get the message from Intel 12 on Windows 7 64 bits:
warning #6075: The data type of the actual argument does not match the definition. [FHANDLE]
The data type of the actual argument does not match the definition. [II]
What is the problem here?
best regards,
Erik
You have declared as INTEGER(4) variables that need to be an addressed-sized integer. In the call to ZeroMemory, the length is INTEGER(SIZE_T). You also have a handle that is apparently declared as INTEGER(4) - this should be INTEGER(HANDLE).
Frederik_Vandenberg
Hi Steve,
It is already a while back, but your answer helped me to solve the problem quickly.
Frederik
