29429 Discussions
Compiler warnings are now hard errors
Noel_B_
5 900 Visites
We recently upgraded to VS 2022 17.7.7 with the latest OneAPI.
Compiling with Intelr Fortran Compiler Classic 2021.11.0 [Intel(R) 64]...
What used to be spurious warnings about function return values not being defined, are now hard error, here's the diagnostics:
$ cmake --build . -j 8 --target ALL_BUILD --config Release
Microsoft Visual Studio 2022 Version 17.7.7.
Copyright (C) Microsoft Corp. All rights reserved.
Build started...
1>------ Build started: Project: always_check_git, Configuration: Release x64 ------
2>------ Build started: Project: libmelcor, Configuration: Release x64 ------
graph_sm.f90
src\modernization\graph_sm.f90(357): error #6178: The return value of this FUNCTION has not been defined.   [NUM_UNDIRECTED_VERTICES]
src\modernization\graph_sm.f90(363): error #6178: The return value of this FUNCTION has not been defined.   [NUM_UNDIRECTED_EDGES]
src\modernization\graph_sm.f90(427): error #6178: The return value of this FUNCTION has not been defined.   [FIND_UNDIRECTED_EDGE]
src\modernization\graph_sm.f90(493): error #6178: The return value of this FUNCTION has not been defined.   [INSERT_UNDIRECTED_EDGE]
src\modernization\graph_sm.f90(663): error #6178: The return value of this FUNCTION has not been defined.   [EDGE_UDG]
src\modernization\graph_sm.f90(677): error #6178: The return value of this FUNCTION has not been defined.   [EDGE_DG]
The function for the first error above is declared in a module interface as follow:
  interface num_vertices
    module function num_undirected_vertices(self) result(n)
      type(graph_t), intent(in) :: self
      integer(int_kind) :: n
    end function
  end interface
and the implementation is in a submodule as follows:
    n = self%num_vertices
  end function
It appears to us (and to gfortran) that this is valid code, is the compiler diagnostic wrong or is there something wrong with our code?.  Any ideas?
20 Réponses
andrew_4619
Contributeur émérite III
5 882 Visites
well I never see such errors something is confusing he compiler. Some thoughts is int_kind a non-default integer? what is the type/kind of self%num_vertices?
0 Compliments
Noel_B_
5 878 Visites
  integer, parameter :: int_kind = 4
  type :: graph_t
    type(multimap_ik_t) :: adjacency
    type(vertex_container_t), pointer :: vertices(:) => null()
    type(edge_container_t), pointer :: edges(:) => null()
    integer(int_kind) :: num_edges = zero_ik
    integer(int_kind) :: num_vertices = zero_ik
    integer(int_kind) :: size_edges = ten_ik
    integer(int_kind) :: size_vertices = ten_ik
  contains
    procedure :: breadth_first_traversal
    final :: destruct_graph
  end type
Note that both ifort and ifx used to complain (warn) about this code, now they both give errors with latest OneAPI.  Further, we see the exact same behavior with latest OneAPI on Linux (both ifort and ifx give errors).  The older ifort on the Mac warns about this code.
0 Compliments
andrew_4619
5 853 Visites
You give only code fragments, I made a test case maybe it misrepresents your code?? It compiles fine in IFX and IFORT.
Does that give an error? Maybe some specific build options are needed? You need a simple reproducer if there is a bug  that needs to be fixed.
ifx /c test.f90
Intel(R) Fortran Compiler for applications running on Intel(R) 64, Version 2024.0.0 Build 20231017
Copyright (C) 1985-2023 Intel Corporation. All rights reserved.
ifort /c test.f90
Intel(R) Fortran Intel(R) 64 Compiler Classic for applications running on Intel(R) 64, Version 2021.11.0 Build 20231010_000000
module fred
    implicit none
    type :: graph_t
        integer(int_kind) :: thing=0
    end type graph_t
        end function
    end interface
end module
submodule(fred) billy
    contains
        n = self%thing
    end function
end submodule billy
0 Compliments
Steve_Lionel
5 840 Visites
You don't show the compiler options used. Those messages are usually warnings, but you probably have /warn:errors enabled.
0 Compliments
Noel_B_
5 822 Visites
Here's a very small reproducer, files are attached.  This warning is on Mac:
ifort (IFORT) 2021.10.0 20230609
but it's the same problems on Linux and Windows.
ifort -c -g vector.f90 vector_sm.f90
vector_sm.f90(26): warning #6178: The return value of this FUNCTION has not been defined.   [GET_VECTOR_BK]
  module function get_vector_bk(self, n) result(data)
vector_sm.f90(65): warning #6178: The return value of this FUNCTION has not been defined.   [SIZE_VECTOR_BK]
  module function size_vector_bk(self) result(size)
Steve_Lionel
5 812 Visites
OK, now these are warnings, not errors. I do agree that they are spurious.
0 Compliments
Noel_B_
5 796 Visites
Unfortunately, we have to compile with warnings as errors, high consequence software, so now that the latest (2024.0) ifort and ifx detect and report this spurious diagnostic as an error, we are dead in the water.  For us, this is a showstopper since it precludes us from using any OneAPI starting in 2024.0, meaning we can't use the, to be released, llvm-based ifx.
We have tried to find a way to suppress this warning so it doesn't get reported, but have been unsuccessful.  Perhaps you know of a way to suppress this warning?
0 Compliments
andrew_4619
5 750 Visites
I played with your reproducer and get the same behaviour. I changed various things e.g. removed variable that are fortran words and various other things and I can't see the trigger for the warning. I have many example using result() that compile just fine so I am not sure what it is that triggers this..... Intel need to look at it !
0 Compliments
andrew_4619
5 742 Visites
The trigger is "final :: destruct_vector_ik" in the type, comment out that line and it compiles with no warnings!!!! I have no explanation!
Noel_B_
5 673 Visites
Well, that's a strange bug, thanks for tracking that down Andrew!  Unfortunately that doesn't help me out too much, I can't remove all of our class destructors.
0 Compliments
andrew_4619
5 658 Visites
You only get the warning for the _bk type but NOT the _ik type routines and those also have final!!!!!
0 Compliments
Noel_B_
5 652 Visites
We have several hundreds of these warnings across dozens of classes, we use a fair number of functions.  The integer kind (ik) types also emit warnings, I just happened to have pruned some of those functions in the course of trying to generate the reproducer.
0 Compliments
Barbara_P_Intel
Employé
5 647 Visites
@Noel_B_, thanks for the reproducer. Did your code ever compile without the warning? What Intel compiler version? I experimented with some previous releases and always get the warning.
@andrew_4619, nice sleuthing!
0 Compliments
andrew_4619
5 628 Visites
I think it also relates to having a generic interface that spans more than one type.....
Noel_B_
5 618 Visites
From what I can recall, the warning has always been there.
0 Compliments
Barbara_P_Intel
Employé
5 569 Visites
Thanks, @Noel_B_, so this isn't a new warning. I wanted to check if this is a regression.
What's new is that you now need to compile with -warn errors.
I filed a bug report for you, CMPLRLLVM-56908. This impacts both ifx and ifort since they share the front end.
Thank you for reporting this.
0 Compliments
FortranFan
5 554 Visites
@Noel_B_ ,
@Barbara_P_Intel has followed up on your issue and filed a compiler bug report.  Since that can take a while to resolve, here is a workaround you may want to think through and evaluate whether your actual code can make use of it: this workaround is silly, but it is to avoid names of objects that are the same as intrinsic statements and/or subprograms in the language supported by Intel compiler viz. names such as DATA, SIZE, etc.  This is only so you can make it a bit easier on your compiler, ideally you won't need it.  See below using IFX 2024.0.2.0:
C:\Temp>ifx /c /standard-semantics /warn:all /warn:errors vector.f90
Intel(R) Fortran Compiler for applications running on Intel(R) 64, Version 2024.0.2 Build 20231213
C:\Temp>ifx /c /standard-semantics /warn:all /warn:errors vector_sm.f90
C:\Temp>
  • Workaround in your file vector.f90
! Author: K. Noel Belcourt
module vector_m
  implicit none
  type :: vector_bk_t
    logical(4), pointer :: data(:) => null()
    integer(4) :: allocated_size = 0
    integer(4) :: n = 0
  contains
    procedure :: construct_vector_bk
    final :: destruct_vector_bk
  end type
  type :: vector_ik_t
    integer(4), pointer :: data(:) => null()
    integer(4) :: n = 0
  contains
    procedure :: construct_vector_ik
  end type
  interface
    module subroutine construct_vector_bk(self)
      class(vector_bk_t), intent(inout) :: self
    end subroutine
    module subroutine construct_vector_ik(self)
      class(vector_ik_t), intent(inout) :: self
    end subroutine
  end interface
  interface
    module subroutine destruct_vector_bk(self)
      type(vector_bk_t), intent(inout) :: self
    end subroutine
    module subroutine destruct_vector_ik(self)
      type(vector_ik_t), intent(inout) :: self
    end subroutine
  end interface
  interface size
    module function size_vector_bk(self) result(siz)
      type(vector_bk_t), intent(in) :: self
      integer(4) :: siz
    end function
    module function size_vector_ik(self) result(siz)
      type(vector_ik_t), intent(in) :: self
      integer(4) :: siz
    end function
  end interface
  interface push_back
    module subroutine push_back_bk(self, b)
      logical(4), intent(in) :: b
    end subroutine
    module subroutine push_back_ik(self, i)
      integer(4), intent(in) :: i
    end subroutine
  end interface
  interface
    module subroutine insert_vector_ik(self, existing, new)
      integer(4), intent(in) :: existing, new
    end subroutine
  end interface
  interface get
    module function get_vector_bk(self, n) result(dat)
      integer(4), intent(in) :: n
      logical(4) :: dat
    end function
    module function get_vector_ik(self, n) result(dat)
      integer(4) :: dat
    end function
  end interface
  interface clear
    module subroutine clear_vector_bk(self)
    end subroutine
    module subroutine clear_vector_ik(self)
    end subroutine
  end interface
  interface set
    module subroutine set_vector_bk(self, n, value)
      logical(4), intent(in) :: value
    end subroutine
    module subroutine set_vector_ik(self, n, value)
      integer(4), intent(in) :: value
    end subroutine
  end interface
end module
  • And in your submodule
submodule (vector_m) vector_sm
  implicit none
contains
    integer(4) :: i
    self%n = 0
    self%allocated_size = 10
    allocate(self%data(self%allocated_size))
    do i = 1, self%allocated_size
      self%data(i) = .false.
    enddo
  end subroutine
    if (associated(self%data)) deallocate(self%data)
  end subroutine
    logical(4) :: dat
    dat = .false.
    dat = self%data(n)
  end function
    logical(4), pointer, dimension(:) :: tmp
    real(8) :: s
    integer(4) :: i
    if (self%allocated_size == self%n) then
      tmp => self%data
      s = self%allocated_size
      self%allocated_size = s * 1.5
      do i = 1, self%n
        self%data(i) = tmp(i)
      enddo
      deallocate(tmp)
    endif
    self%n = self%n + 1
    self%data(self%n) = b
  end subroutine
    self%data(n) = value
  end subroutine
    integer(4) :: siz
    siz = self%n
  end function
    self%n = 0
    self%data = 0
  end subroutine
    ! if (associated(self%data)) deallocate(self%data)
    self%n = 0
    self%allocated_size = 0
    self%data => null()
  end subroutine
    integer(4) :: dat
    dat = 0
    dat = self%data(n)
  end function
    integer(4), pointer, dimension(:) :: tmp
    real(8) :: s
    integer(4) :: j
      tmp => self%data
      do j = 1, self%n
        self%data(j) = tmp(j)
      enddo
      deallocate(tmp)
    endif
    self%n = self%n + 1
    self%data(self%n) = i
  end subroutine
  end subroutine
    integer(4) :: siz
    siz = self%n
  end function
end submodule
0 Compliments
Noel_B_
5 492 Visites
I could see that this:
could fix some of the issues, but many of our functions have problems and the names, to the best of my knowledge, are not the names of intrinsics.  For example, none of these function return values (n, edge, e) are the names of intrinsics or subprograms, as far as I know.  So I'm not sure that's the whole explanation, seems like there could be more going on with this.
graph_sm.f90(357): warning #6178: The return value of this FUNCTION has not been defined.   [NUM_UNDIRECTED_VERTICES]
graph_sm.f90(363): warning #6178: The return value of this FUNCTION has not been defined.   [NUM_UNDIRECTED_EDGES]
  module function num_undirected_edges(self) result(n)
graph_sm.f90(427): warning #6178: The return value of this FUNCTION has not been defined.   [FIND_UNDIRECTED_EDGE]
  module function find_undirected_edge(self, u_id, v_id) result(edge)
graph_sm.f90(493): warning #6178: The return value of this FUNCTION has not been defined.   [INSERT_UNDIRECTED_EDGE]
  module function insert_undirected_edge(self, u, v) result(edge)
graph_sm.f90(663): warning #6178: The return value of this FUNCTION has not been defined.   [EDGE_UDG]
  module function edge_udg(self, i) result(e)
graph_sm.f90(677): warning #6178: The return value of this FUNCTION has not been defined.   [EDGE_DG]
  module function edge_dg(self, i) result(e)
0 Compliments
andrew_4619
5 477 Visites
Yes it seems the compilers is screwing up its lists of variable names/attributes or something like that and that it could then be become sensitive  to more than one thing that exposes the otherwise hidden problem.  It is worth intel looking at it as there could be other hidden side effects/possibilities  as yet unknown.
0 Compliments
andrew_4619
5 541 Visites
Well @FortranFan   I am right royally confused! What you have done there with data and size was my first guess at  a key to the issue.  I "proved" to myself the changes like you made didn't 'fix' it.  I have just tested your code and it it is OK  but having deleted my earlier files I now don't know why my edits failed. Very annoying!!!!!! Anyway chapeau again!
0 Compliments
Répondre
