29487 Discussions
GNU intrinsic procedures are not recognized by IFX
Rubo
ifx does not recognized some of the intrinsic procedures available for GNU compilers: error #6404: This name does not have a type, and must have an explicit type. [RENAME] file_status = rename(trim(f1), trim(f2)) --------------------------^ error #6404: This name does not have a type, and must have an explicit type. [CHMOD] status = chmod(pathname, mode) !! intrinsic GNU -----------------^ error #6404: This name does not have a type, and must have an explicit type. [STAT] status = stat(trim(adjustl(filename)), buffer) -----------------^ error #6404: This name does not have a type, and must have an explicit type. [GETCWD] io_status = getcwd(cwd) --------------------^ error #6404: This name does not have a type, and must have an explicit type. [CHDIR] io_status = chdir(trim(targetdir)) ------------------------^ error #6404: This name does not have a type, and must have an explicit type. [IERRNO] err = int(IERRNO(), kind=4 ) --------------------------^ error #6362: The data types of the argument(s) are invalid. [INT] err = int(IERRNO(), kind=4 ) --------------------------^ error #6404: This name does not have a type, and must have an explicit type. [GETPID] get_process_id = getpid() -------------------------^ error #6404: This name does not have a type, and must have an explicit type. [GETUID] get_login_id = getuid() -----------------------^
Any ideas on how to solve this issue?
Steve_Lionel
Most (if not all - I didn't check) of these are in the Portability Library. Portability Library Routines (intel.com)
andrew_4619
You can replace non-standard GNU extensions with non-standard Intel extensions. A better quick fix is to call your own functions e.g. "myRename" , "myCHMOD" etc as simple wrappers and then just have the non-standard extensions in one occurrence in one place.  It will improve the portability and by replacing one compiler specific source file you have compatibility with both systems.
mecej4
A few words of caution, as expressed years ago by @Steve_Lionel:
"There is no guarantee that any of the 'portability' procedures are implemented the same with other compilers. There are several I know of that have different interfaces and behaviors depending on the compiler. You're not guaranteeing portability by avoiding IFPORT."
