29390 Discussions
Compiling Calculix with Visual Studio and ifort
habermann__richard
I am trying to build Calculix (for example here: https://github.com/prool/ccx_prool/tree/master/CalculiX/ccx_2.15/src) in Visual Studio 2015 with Intel Fortran. Normally it is built with gcc and gfortran. It mixes C and Fortran, and I am having troubles now with arrays dynamically allocated in C because in Fortran ifort expects a dimension.
subroutine calinput(kon)
implicit none
integer(C_LONG_LONG) kon(*)
But this is working:
      subroutine calinput_c(kon, kons) bind(C)
      USE, INTRINSIC :: ISO_C_BINDING
      implicit none
      integer(C_LONG_LONG) kons
      integer(C_LONG_LONG), DIMENSION(kons) ::kon
      kon(1) = kon(1)
      return
      end
Is there a way to get the first variant to compile with ifort?
There was some work done previously to compile calculix, can I get the files?
https://software.intel.com/en-us/forums/intel-c-compiler/topic/536919
Thank you in advance!
Steve_Lionel
You don't say what isn't working in the first case. I am going to assume that your original code included "USE, INTRINSIC :: ISO_C_BINDING" as otherwise C_LONG_LONG would not be declared.
I will guess that one problem is that the C code assumes that the Fortran routine is named "callinput" in lowercase. Intel Fortran on Windows uses upper case for routine names, but gfortran does not. The addition of BIND(C) causes Intel Fortran to use lower case.
If neither of these are the problem, please provide more details, as the use of an assumed size array should work. The second code of course is also fine.
habermann__richard
Oh, ok. This does work!
I think I mixed up the binding, thank you!
Marine__James
Hi Rechard, i am also working to compile CCX using Visual Studio and ifort, if you don't mind, may i ask whether you could share the VS projects with me? my email: tjumsl@outlook.com
