29429 Discussions
Compiling Error: "Can't open file x64/Release/myfile.obj to write"?
Nan_Deng
I got a weird error in updating my programs. The programs have been compiled before and the set up didn't change. But now I cannot compile, not even modify the code. Trying to re-compile the original program give me the message "Error: Can't open file x64/Release/myfile.obj to write", but the file is there and is not write-protected. What is the cause of the error and how can I fix it?  Is there any part of compiler crushed/damaged/virus infected? How can I repair it?
TimP
It's likely just an ordinary windows file busy lock
Nan_Deng
It is possible. However, I tried to reboot the machine twice. stopped all other jobs, (99% of RAM and 200GB of HD available), disconnect from network, and re-run the original installation for repair.  After all those, I still cannot edit the source and save the file, and when I tried to recompile it still failed (The same profile compiles perfectly a while ago).  Do you think this is a windows problem or compiler problem?  When I deleted the old myfile.obj files, the compiler gave another error " Error #7001: fail to create the myfile.obj file". Funny thing is, it can create the obj files for some subroutines, but not for others.  Any suggestions on how to fix it?
You can't save the source file? It is almost certainly a problem with your Windows system and not the compiler. Do you have an antivirus program you could try stopping temporarily? Sometimes these interfere with builds.
