29642 Discussions
Compiling F95 files using intel fortran and visual studio
skravoof
Dear all,
I am using intel fortran 11.1.1060 with Visual studio 2008. Is there any way I can compile .f95 files? I heard about -Tf compiler options if you want to use command prompt. is there any place that I activate this options in Visual studio?
skravoof
.f95 is a non-standard file type for free-form source code. I suggest renaming the files to the more widely accepted .f90. There is a spot under Tools > Options > Intel Visual Fortran > General where you can add .f95 as a free-form source type, but I know there were some issues with this in some 11.1 versions. You can try 11.1 Update 7 to see if that had the fix (I am uncertain) or install the current version 12.0 Update 2.
I don't think you can make -Tf work from Visual Studio.
