29653 Discussions
Compiling a FortranIV Programm on Intel Visual Fortran Compiler for Linux
florian_hanne1
I have a problem compiling an old FortranIV Program. I really do not understand the error message I get when I try to compile the program. Since I re-typed the program, I cannot ensure it is free of bugs, but still after double-checking, I do not see a mistake.
Thanks for your help.
Florian
Here comes the error message:
fortcom: Error: /home/hiwiad00/BOERGER_070510.f, line 154: Syntax error, found END-OF-STATEMENT when expecting one of: = .EQV. .NEQV. .XOR. .OR. .AND. .LT. < .LE. <= .EQ. == .NE. /= .GT. > ...
35 ETAG(I,1)=ETAG(I,1)+GISELA(AK(NPO1),AK(NPO2),AK(NPO3),AK(NPO4),XI(NPO1),XI(NPO2),XI(NPO3),XI(NPO4),XIG(I))
fortcom: Error: /home/hiwiad00/BOERGER_070510.f, line 145: An unterminated block exists.
Do 35 II=1,NA
fortcom: Error: /home/hiwiad00/BOERGER_070510.f, line 145: This label is undefined. [35]
Do 35 II=1,NA
compilation aborted for /home/hiwiad00/BOERGER_070510.f (code 1)
florian_hanne1
Hello again,
I have reduced the problem to the following line:
What ist wrong with this line? It seems like the compiler expects some sort of logical extension (OR, AND, XOR...) but this is an Equation within an Iteration...
If you need additional information, please let me know. the whole program consists of 190 lines, so I could post it as a txt-file.
Thanks for helping me!
Florian
The line is much too long for a FORTRAN IV statement, which is limited to 72 characters. If the file type is .f or .for, then it is fixed-form source and has the 72-character limit/
I suggest attaching the source to a reply so we can see what we're dealing with. I don't want to give advice based on an assumption.
florian_hanne1
Thanks!
That was one of the problems. Attached is the file, I have made some changes to the original version, especially defining "Gisela" as a function.
Another big problem are the "format" entries - when I activate these (delete the "c" at the beginning of the line) I get a lot of error messages. What is wrong with these format definitions?
If you see any big mistakes, please let me know! Thank you so much for your support. You really help me a lot!
Florian
Fixed-form source has peculiar rules. The statement number field (the "15" in the FORMAT) must be in columna 1-5. Continuation indicators, which are the digits 1 and2 in this case, must be in column 6. The statement text itself starts in column 7 and runs through 72. Further complicating is that this source file has tabs, which can confuse things.
The format should look like this:
!234567
15    FORMAT (' RMAX='F10.6,'M'/' EM ='F10.6/' XL = 'F10.6/' WH =
     1	'F10.6/' WL = 'F10.6/' WS='F10.6/' DD ='F10.6/'
     2	 XV ='F10.6/' DX = 'F10.6,'M')
Delete any tabs in these lines and make sure the spacing is as shown.
One additional problem I see is line 68, which is one character too long. Just remove the space before GISELA and you shouldbe ok.
florian_hanne1
Thank you,
at least I can compile the program now. Now I still have some problems with the formula, but that is more physics than programming (hopefully).
Thanks a lot!
If I find new problems excelling my programming skills - I will bother you again! Open-mouthed smiley [:-D]
Thanks!
