compatibility problem CVF <--> IVF
vriesdwj
Untill last week we used CVF, but now we try to port our applications to IVF.
We are having problems with the next piece of code.
In CVF it runs and says at the end itra=1.
In IVF it crashes because i(0) is going to be evaluated in the WHILE statement.
Is there an option in the IVF compiler to handle this problem.
This kind of syntax is often used in our code, so I don't want to rewrite it.
Thanks in advance,
Wilco de Vries
program test
implicit none
integer itra
real*4 i(4)
itra = 4
i=4
! Original code
DO WHILE (itra.GT.1 .AND. 3 .LE. i(itra-1))
itra = itra - 1
ENDDO
write(6,*) itra
end program test
This is an error in your code which you will have to fix. Read this article, which I wrote while working on CVF. As you'll see, CVF could behave this way too for many applications.
