ifort error using -static option
postaquestion
Hi - I am getting the error of unresolved _Unwind_GetCFA, _Unwind_GetBSP, and _Unwind_Backtrace when I use -static option.
Followingis the compilation output. You can locate the error line by searching for 'Error'. Any solution on how to get rid of them?
sdwivedi@isp-curran:~/PCODE/arb/MESO/NEW-CONTACT/new-mat30/sand> make -f newmake2
ifort -w -c -fnsplit -integer_size 64 -real_size 64 -ip -ipo -mp -mtune=itanium2 -tpp2 -O2 -openmp -parallel -static varbl.f90
ifort -w -c -fnsplit -integer_size 64 -real_size 64 -ip -ipo -mp -mtune=itanium2 -tpp2 -O2 -openmp -parallel -static mat1.f90
ifort -w -c -fnsplit -integer_size 64 -real_size 64 -ip -ipo -mp -mtune=itanium2 -tpp2 -O2 -openmp -parallel -static mat2.f90
ifort -w -c -fnsplit -integer_size 64 -real_size 64 -ip -ipo -mp -mtune=itanium2 -tpp2 -O2 -openmp -parallel -static mat3-new.f90
ifort -w -c -fnsplit -integer_size 64 -real_size 64 -ip -ipo -mp -mtune=itanium2 -tpp2 -O2 -openmp -parallel -static mat4.f90
ifort -w -c -fnsplit -integer_size 64 -real_size 64 -ip -ipo -mp -mtune=itanium2 -tpp2 -O2 -openmp -parallel -static mat6.f90
ifort -w -c -fnsplit -integer_size 64 -real_size 64 -ip -ipo -mp -mtune=itanium2 -tpp2 -O2 -openmp -parallel -static mat7-new.f90
ifort -w -c -fnsplit -integer_size 64 -real_size 64 -ip -ipo -mp -mtune=itanium2 -tpp2 -O2 -openmp -parallel -static mat30-new.f90
ifort -w -c -fnsplit -integer_size 64 -real_size 64 -ip -ipo -mp -mtune=itanium2 -tpp2 -O2 -openmp -parallel -static str1.f90
ifort -w -c -fnsplit -integer_size 64 -real_size 64 -ip -ipo -mp -mtune=itanium2 -tpp2 -O2 -openmp -parallel -static autoc-new2-sand2.f90
ifort -w -c -fnsplit -integer_size 64 -real_size 64 -ip -ipo -mp -mtune=itanium2 -tpp2 -O2 -openmp -parallel -static analys.f90
ifort -w -c -fnsplit -integer_size 64 -real_size 64 -ip -ipo -mp -mtune=itanium2 -tpp2 -O2 -openmp -parallel -static main.f90
ifort -w -fnsplit -integer_size 64 -real_size 64 -ip -ipo -mp -mtune=itanium2 -tpp2 -O2 -openmp -parallel -static -o isp2d1-trial varbl.o mat1.o mat2.o mat3-new.o mat4.o mat6.o mat7-new.o mat30-new.o str1.o autoc-new2-sand2.o analys.o main.o
IPO Error: unresolved : _Unwind_GetCFA
Referenced in libpthread.a(unwind.o)
IPO Error: unresolved : _Unwind_GetBSP
IPO Error: unresolved : _Unwind_Backtrace
Referenced in libc.a(backtrace.o)
IPO: performing multi-file optimizations
IPO: generating object file /tmp/ipo_ifortH1hiUi.o
analys.f90(2665) : (col. 2) remark: LOOP WAS AUTO-PARALLELIZED.
analys.f90(2722) : (col. 2) remark: LOOP WAS AUTO-PARALLELIZED.
analys.f90(2798) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
analys.f90(2825) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
analys.f90(2852) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
analys.f90(2872) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
analys.f90(2898) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
analys.f90(2918) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
analys.f90(2940) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
a nalys.f90(2959) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
analys.f90(2985) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
analys.f90(3019) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
analys.f90(3051) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
analys.f90(3067) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
analys.f90(3093) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
analys.f90(3111) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
analys.f90(3128) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
analys.f90(3188) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
analys.f90(3216) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
analys.f90(3263) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
analys.f90(6319) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
analys.f90(6389) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
analys.f90(6677) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
analys.f90(6808) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
autoc-new2-sand2.f90(208) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
autoc-new2-sand2.f90(250) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
autoc-new2-sand2.f90(269) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
autoc-new2-sand2.f90(740) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
autoc-new2-sand2.f90(761) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
autoc-new2-sand2.f90(794) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
autoc-new2-sand2.f90(838) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
autoc-new2-sand2.f90(852) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
analys.f90(3354) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
analys.f90(3403) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
analys.f90(3423) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
analys.f90(3445) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
analys.f90(3466) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
analys.f90(3492) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
str1.f90(128) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
str1.f90(163) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
str1.f90(630) : (col. 4) remark: LOOP WAS AUTO-PARALLELIZED.
str1.f90(617) : (col. 4) remark: LOOP WAS AUTO-PARALLELIZED.
str1.f90(685) : (col. 4) remark: LOOP WAS AUTO-PARALLELIZED.
analys.f90(4429) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
analys.f90(3707) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
analys.f90(3723) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
analys.f90(3802) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
analys.f90(4052) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
analys.f90(4224) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
analys.f90(4257) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
analys.f90(4563) : (col. 2) remark: LOOP WAS AUTO-PARALLELIZED.
analys.f90(4802) : (col. 2) remark: LOOP WAS AUTO-PARALLELIZED.
analys.f90(4854) : (col. 2) remark: LOOP WAS AUTO-PARALLELIZED.
analys.f90(5130) : (col. 2) remark: LOOP WAS AUTO-PARALLELIZED.
analys.f90(7384) : (col. 2) remark: LOOP WAS AUTO -PARALLELIZED.
analys.f90(7493) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
analys.f90(7567) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
autoc-new2-sand2.f90(1430) : (col. 3) remark: LOOP WAS AUTO-PARALLELIZED.
autoc-new2-sand2.f90(1445) : (col. 3) remark: LOOP WAS AUTO-PARALLELIZED.
analys.f90(7061) : (col. 2) remark: LOOP WAS AUTO-PARALLELIZED.
analys.f90(7190) : (col. 2) remark: LOOP WAS AUTO-PARALLELIZED.
analys.f90(7244) : (col. 3) remark: LOOP WAS AUTO-PARALLELIZED.
analys.f90(7314) : (col. 2) remark: LOOP WAS AUTO-PARALLELIZED.
analys.f90(7408) : (col. 2) remark: LOOP WAS AUTO-PARALLELIZED.
analys.f90(2035) : (col. 2) remark: LOOP WAS AUTO-PARALLELIZED.
analys.f90(2236) : (col. 2) remark: LOOP WAS AUTO-PARALLELIZED.
analys.f90(2406) : (col. 2) remark: LOOP WAS AUTO-PARALLELIZED.
analys.f90(2460) : (col. 2) remark: LOOP WAS AUTO-PARALLELIZED.
analys.f90(2617) : (col. 2) remark: LOOP WAS AUTO-PARALLELIZED.
autoc-new2-sand2.f90(56) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
autoc-new2-sand2.f90(67) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
autoc-new2-sand2.f90(79) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
autoc-new2-sand2.f90(92) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
autoc-new2-sand2.f90(111) : (col. 6) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
/usr/lib/gcc/ia64-suse-linux/4.1.0/../../..//libpthread.a(unwind.o): In function `unwind_stop':
(.text+0x1f2): undefined reference to `_Unwind_GetCFA'
(.text+0x262): undefined reference to `_Unwind_GetBSP'
(.text+0x2d2): undefined reference to `_Unwind_GetCFA'
/usr/lib/gcc/ia64-suse-linux/4.1.0/../../..//libc.a(backtrace.o): In function `backtrace':
(.text+0x62): undefined reference to `_Unwind_Backtrace'
make: *** [isp2d1-trial] Error 1
Try adding -cxxlib to the command that does the link. This is not an area I am very familiar with, so if this does not help, please file an issue with Intel Premier Support.
TimP
Depending on the distro, the required libraries may be in libunwind. If that library is present, adding -lunwind should fix it. This kind ofsituation is the reason why you must specify compiler and linux versions when reporting a problem, even if you are running unsupported versions.
