29253 ディスカッション
Compiling and Runing an OpenMP code with Intel Fortran 11.1 on Mac OS X from the command line
Andreas_Hoffie
ビギナー
664件の閲覧回数
Hi All,
I am trying to compile and run an OpenMP code (that worked under Linux) from the command line from Mac without success so far:
to compile I enter (F77):
" ifort -o 'executable' 'sourcecode.f' -openmp "
export OMP variable (for example):
" export OMP_NUM_THREADS=2 "
and to run the code:
" ./'executable' "
This gives me the following error message:
dyld: Library not loaded: libiomp5.dylib
Referenced from: /Users/andreasf/2_CLASSES/fall2009/MAE_609-HighPerformanceComputing/HW-2_OMP&MPI/./pi
Reason: image not found
Trace/BPT trap
What am I doing wrong?
Does the path for the omp libraries have to be included in the .bashrc? This is the line in my .bashrc so far:/opt/intel/Compiler/11.1/080/bin/ifortvars.sh intel64.
How does the procedure look like, if F90 is used?
Thank you!
Andreas
0 件の賞賛
3 返答(返信)
Xiaoping_D_Intel
従業員
664件の閲覧回数
The error was caused by missing ifort environment variables. The correct line is:
source /opt/intel/Compiler/11.1/080/bin/ifortvars.sh intel64
If you want to set it up in your login shell the line needs to be put into ".bash_login" or ".bash_profile" instead of ".bashrc".
Andreas_Hoffie
ビギナー
664件の閲覧回数
Its working. Thank you!
ILeao
初心者
664件の閲覧回数
 I found two simple solutions for this drawback:
Solution 1 : using install_name_tool  fort for libiomp5.dylib in your executable file only (if you recompile you'll need to do this again...)
install_name_tool -change libiomp5.dylib /opt/intel/composer_xe_2013_sp1.2.139/compiler/lib/libiomp5.dylib /executable_file
solution 2 : it's a similar solution provided by xiaoping-duan (valid until reboot only) if you don't use any other fortran compile on mac as I, put it .bash_profile. Take care only .bash_profile to run on MAC OS x is a little bit weird! Please check the following link http://apple.stackexchange.com/questions/107441/os-x-mavericks-bash-profile-paths-dont-work
source /opt/intel/composer_xe_2013_sp1.2.139/bin/ifortvars.sh  intel64
and now it`s working fine...
Best wishes,
ileao
返信
