29648 Discussions
Compiling with Microsoft Visual Studio
rafadix08
I noticed that my programs are much bigger in size and much slower to run when I compile them using Microsoft Visual Studio compared to when I compile them directly using ifort in the command line.
Is there something I have to set up in Microsoft Visual Studio in order to make the executable runfaster?
Thank you,
Rafael
My guess is that you are building a Debug configuration in Visual Studio. Select the Release configuration and the sizes and performance should be similar to builds from the command line (assuming default options.)
sarma_amras
we have the optimization tab in the properties -> Fortran -> optimization.
Try to change it to the maximum speed. It might be helpful some way.
