29631 Discussions
Compiling with XE-2011 Fortran Compiler
amos2
I have been trying to configure, compile, and make both openmpi-1.4.3 and espresso-4.3.1 using the intel fortran and C compilers and have run into a problem with both of these programs. The system is using SuSE Linux 11.4 running on VMware 7.0.1. Both programs appear to go through the processes to completion but when I try to run examples that are in the program both of them fail with the error message: mpicc hello_c.c -o hello_c mpicc: error while loading shared libraries: libimf.so: cannot open shared object file: No such file or directory I have checked and found that the libimf.so file is present at the location: /opt/intel/composerxe-2011.5.220/compiler/lib/intel64 . I have checked the permissions for the file and it seems to be correct and so at this point I have no idea what the diffculty is. Any help would be much appreciated. Amos Leffler
mecej4
The configuration of mpicc that you built may not have the Intel library directory as a default location for libraries to search.
In place of the command that you showed, try
export ILIBD = /opt/intel/composerxe-2011.5.220/compiler/lib/intel64
export LD_LIBRARY_PATH=$ILIBD:$LD_LIBRARY_PATH
mpicc hello_c.c -o hello_c -L $ILIBD
I'm working with kiva 3V and I need to add a subroutine written in fortran to intel fortran path. Anyone know how I can do that?
Thank you.
TimP
The expectation is that you have sourced the Intel compilervars script in the run environment, just as you would for compilation.
