Compliling error for Windows XP
Ahmed_A_2
Hi
I have installed intel fortran to my computers . In windows 7 ,I have no problem to biuld my project , but if I tried to build the same project it in anther computer with  windows XP I have these building errors
Error 1 Error A license for FCompW could not be obtained
Error 2 error #10052: could not checkout FLEXlm license
Error 3 Error A license for FCompW could not be obtained
Error 4 error #10052: could not checkout FLEXlm license
Error 5 Error A license for FCompW could not be obtained
Error 6 error #10052: could not checkout FLEXlm license
Error 7 Error A license for FCompW could not be obtained
Error 8 error #10052: could not checkout FLEXlm license
it is a kind of repeated errors associated with each subroutine in the project.
Could you please help me to fix these error, I have tried to google it but it was not helpful.
Many thanks
Ahmed
Did you do a regular installation of the compiler product?  Do any files exist in C:\Program Files\Common Files\Intel\Licenses ? Try copying the files from that folder (may be Program Files (x86) on the Win7 system) into the folder I named above on your XP system.
Ahmed_A_2
Hi Steve
Yes I have used regular instlation , and in C:\Program Files\Common Files\Intel\Licenses there are two files
1-EVAL_W__FOR_VR2J-KX9W4WJL.lic
2- USE_SERVER.lic
but it is not clear for me in your reply which files should be copied to which place , could you clarify that for me
Many thanks
Ahmed
The first file is an evaluation license that has expired - you should remove it.  The second file would point to a license server for floating licenses. My guess is that this second file has errors or is pointing to an unavailable license server. See Setting up the client for a floating license for more information. If you need more help, please ask in our Licensing forum.
