Confused by such error message
lorinsz
I'm developing a programe solving large-scale matrix equation using frontal-solver algorithm.(Ax = b)
After compiling and linking (they are both OK), I excuted the programe and got following message:
forrtl: severe (41): insufficient virtual memory
*********************************(some other message)
Incrementally linked image--PC correlation disabled.
so what's the meaning? Could someone tell me that?
Thx~~~~~
"Insufficient virtual memory": I donot think my programe need too much memory, since the matrix I input is not very large, just 900-by-900.
It does indeed mean that your program uses "too much memory". You're using CVF, right?
Add at the end of your compile command
/traceback /link /incremental:no
and it should tell you at what line the error occurred. That may help you figure out the problem.
lorinsz
Thanks for you reply. Yes, I'm using CVF 6.6, so do you mean I have to use the command prompt to compile and link the program? Using DF ... ?
No - if you're using the IDE, just build in a debug configuration, run under the debugger and see where it stops. It's probably on an ALLOCATE but it might be somewhere else.
lorinsz
Great!
I've found the error now, it's really about ALLOCATE.
thx Steve.
