29641 Discussions
Consecutive errors - forrtl: severe (38): error during write
Nick2
In one scenario, I typically run 7 processes at a timethat each load the Fortran dll (essentially a batch queue), until eventually I finish running ~150 cases (each case runs in a new process). The particular machine has two quad Xeon CPUs.
I've noticed the occasional failurewhile the cases are writing to output files;it looks something like this:
Case XYZ4
Date and Time: 5/31/2010 6:21:45 PM
forrtl: severe (38): error during write, unit 89, file XYZ4.something
Case XYZ3
Date and Time: 5/31/2010 6:21:42 PM
forrtl: severe (38): error during write, unit 33, file XYZ3.something
Case XYZ1
Date and Time: 5/31/2010 6:21:31 PM
forrtl: severe (38): error during write, unit 31, file XYZ1.something
Case ZYX1
Date and Time: 5/31/2010 6:19:46 PM
forrtl: severe (38): error during write, unit 92, file ZYX1.something
This isjust aboutimpossible to repro; I only get one such failure out of 150 or so cases (18 clock hours).
Has anyone encountered anything similar?
rasa
This is just a suggestion as the error can be due to a number of factors. You can use "ERR" and "IOMSG" specifers in the WRITE statement to pinpoint the error source.
You can also use ERR as a breakpoint and print the values for debugging purposes.
[fortran]subroutine test()
use, intrinsic :: ISO_FORTRAN_ENV, only: OUTPUT_UNIT
! define local variables
character (len = 200) :: iomessage
real :: a
integer :: ii
continue
! .. blah.. blah..
write(unit = 125, fmt = '(EN10.6,I5)', err = 101, iomsg = iomessage) a, ii
! .. blah .. blah...
return
! error catching
101 continue
! print the values of a and ii
write(OUTPUT_UNIT, *) a, ii, iomessage
stop 'ERROR: ERROR IN WRITE in subroutine test'
end subroutine test[/fortran]
Hope this helps!
"Error during write" means that the OS returned an error during the write operation that didn't map onto a specific Fortran error message. This usually means some sort of media error. If you use IOSTAT to detect the error you can then call ERRSNS and look at the "sys_err" value.
Nick2
Thanks for the help everyone! I still can't repro...but it looks like defrag fixed the problem.
