29487 Discussions
Console1.exe has triggered a breakpoint.
Jianzhong_C_
hi,
      i am new to Fortran. when i am debuging a sample program, it outputs:
'Console1.exe' (Win32): Loaded 'C:\Users\ASUS\Documents\Visual Studio 2015\Projects\Console1\Console1\Debug\Console1.exe'. Module was built without symbols.
'Console1.exe' (Win32): Loaded 'C:\Windows\SysWOW64\ntdll.dll'. Module was built without symbols.
'Console1.exe' (Win32): Loaded 'C:\Windows\SysWOW64\kernel32.dll'. Module was built without symbols.
'Console1.exe' (Win32): Loaded 'C:\Windows\SysWOW64\KernelBase.dll'. Module was built without symbols.
'Console1.exe' (Win32): Loaded 'C:\Windows\SysWOW64\vcruntime140d.dll'. Module was built without symbols.
'Console1.exe' (Win32): Loaded 'C:\Windows\SysWOW64\ucrtbased.dll'. Module was built without symbols.
'Console1.exe' (Win32): Loaded 'C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2016.3.207\windows\redist\ia32_win\compiler\libifcoremdd.dll'. Module was built without symbols.
'Console1.exe' (Win32): Loaded 'C:\Windows\SysWOW64\imagehlp.dll'. Module was built without symbols.
'Console1.exe' (Win32): Loaded 'C:\Windows\SysWOW64\msvcrt.dll'. Module was built without symbols.
'Console1.exe' (Win32): Loaded 'C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2016.3.207\windows\redist\ia32_win\compiler\libmmd.dll'. Module was built without symbols.
The thread 0x33f0 has exited with code -1073741510 (0xc000013a).
The thread 0xe98 has exited with code -1073741510 (0xc000013a).
The thread 0x2f68 has exited with code -1073741510 (0xc000013a).
The thread 0x2220 has exited with code -1073741510 (0xc000013a).
The program '[7384] Console1.exe' has exited with code -1073741510 (0xc000013a).
Next to the console window, it shows a window named Source Not Available with content: Frame not in module
However, when i choose start without debugging, it successfully output to Console1.exe.
I am using windows 10, Microsoft visual studio community 2015 and Parallel studio XE 2016 cluster edition.
Thanks and regards,
There is probably a separate console window "behind" the Visual Studio window with the actual error. Look on the taskbar. Usually this "has triggered a breakpoint" means that a run-time detected error such as out-of-bounds array reference was reported.
