I've a problem to construct a scalar structure (derived-type variable) containing some allocatable derived-type variables.
The type definition and declaration of the structure looks something like that:
[fortran]Type :: MyType
type(MySubType1) ,dimension(:) ,allocatable :: SubVar1
type(MySubType2) :: SubVar2
End Type
Type :: MySubType1
real ,dimension(:) ,allocatable :: rvar
integer ,dimension(:) ,allocatable :: ivar
End Type
Type :: MySubType2
type(MySubSubType1) ,dimension(:) ,allocatable :: SubVar1
type(MySubSubType2) ,dimension(:) ,allocatable :: SubVar2
End Type
type(MyType) :: Var
[/fortran] As you can see, in the present example the Var variable is a scalar structure containing two derived-type components, one scalar and one allocatable array called SubVar1 and SubVar2 respectively.
The problem is that I first construct the SubVar1 and SubVar2 variables and then I store them into the larger structure by simply copying the data using :
[fortran]Var%SubVar2 = SubVar2[/fortran]
However, by doing so, the components in SubVar2 are not allocated in the Var variable.
How can I transfert the allocation status into a new variable.
End Type
Type :: MySubType1
End Type
Type :: MySubType2
End Type
type(MyType) :: Var
Would you please show us a complete sample program that demonstrates the problem? What you have written here should work, as far as I can see.
Please, disreagared the previous post since I have found the (stupide) mistake which was creating the problem.
The problem was simply that I used an intent(out) statment where I should have an intent(inout).
Indeed, I do not directly copying the sub-structure into the upper structure but I am using a procedure which automatically load the sub-structure into the correct structure component. The loading procedure is the following:
[fortran]Subroutine Load_SubStr ( Str, SubStr ) implicit none type(Str_Type) ,intent(inout) :: Str class(*) ,intent(in) :: SubStr select type (SubStr) type is (MyType1); Str%SubStr1 = SubStr type is (MyType2); Str%SubStr2 = SubStr end select End Subroutine[/fortran] The bug was that te Str argument had the intent(out) so that each new component I was loading into the structure was easing the old component which have previousely been loaded into the structure.
Glad to hear it. This is an of example why posting paraphrases and snippets often hides the real problem.
Topic Options
