Control Panel Entries
DavidWhite
Valued Contributor II
How do I clean up the entries in Control Panel?
I still have Compose XE 2013 Update 15 listed as being installed, even though this does not appear in VS.
When I attempt to uninstall the older version, the uninstall fails.
David
FortranFan
You don't recall any issues during any update installation?
Re: clean-up, have you tried some freeware Windows utilities such as CCleanerThis one helps me greatly plus it is very user-friendly.
TimP
In cases where I created confusion by using a different installer for an upgrade, the solution seems to be to use the original installer to remove. Then, if old entries remain in add/remove, they may be amenable to direct removal from the Windows menu.
Having used the Parallel Studio installation, I should have waited for the PS upgrade installer before attempting any upgrades without full removal.
It might be interesting to hear whether freeware utilities help with cleanup, particularly on Win8.1.
Steven_L_Intel1
I generally recommend the Windows Installer Cleanup Utility. This used to be provided by Microsoft but they dropped it.
