Control of screen text
john_humble1
I have a cvf program that requires user input from a DOS screen to be followed by calculated output to the screen. The output echoes the input and then adds further information that needs to be on the same line. Example
MyInput ProgramOutput
The previous VMS version of the program achieved this through screen positioning using escape sequences but I've not foundanything similar in Visual Fortran or its environment. The $ non-advancing formatis ignored in input. My test program
program test_screenresponse
implicit none
integer :: a,b
type '(a)', 'Input a single digit number'
accept '(i1, $)', a
if (a == 1) then
b = 12
else
b = 24
endif
type '(i1, i4)', a, b
end program
produces
1
1 12
while I need it to follow the first '1' with '12' on the first line.
Hope I've made myself clear. Any suggestions anyone?
TIA
John
jimdempseyatthecove
John,
In the IVF compiler documentation use Search and search for
"Displaying Character-Based Text"
You will find a list of IFQWIN functions.
Jim Dempsey
drgfthomas
CVF's C:Program FilesMicrosoft Visual StudioDF98SAMPLESISOVAR has the MODULE ISO_VARYING_STRING which you might have a look at. BTW, it also works with IVF so long as you turn off checking for uninitialized variables.
Your VMS program used "ANSI escape sequences" (made popular by the DEC VT100) to set text color and position. Microsoft supported those in 16-bit Windows with an ANSI.SYS driver but dropped support for it with 32-bit applications under Windows NT and later.
Windows has a set of "console output" routines that can do these things, but they are harder to use than just inserting escape sequences.
Gerry, I can't figure out how ISO_VARYING_STRINGS relates to this question.
john_humble1
Thank you Jim (and also Gerry). Knowing the right search string to use makes all the difference! I'd not found these functions previously.
John
You say that the $ is ignored, but that's because you put it on the ACCEPT format. $ has meaning for output only. You also have to open the file with CARRIAGECONTROL='FORTRAN'.
Unfortunately, there's no way to eliminate the new line after the user presses Enter. What you CAN do is use a routine such as GETCHARQQ to wait for a single keypress and then continue. Consider the following version of your code:
use ifcore
implicit none
integer :: a,b
character c
open (unit=6, carriagecontrol='fortran',form='formatted')
write (6, '(a)') ' Input a single digit number'
c = getcharqq()
if (c == '1') then
b = 12
else
b = 24
endif
write (6, "('+',a1, i4)") c, b
end program
drgfthomas
John stated:
I do this a lot via ISO_VARYING_STRINGS. It's part of modern Fortran and is OS invariant. It works like a charm but YMMV.
