Hi there,
Im using IVF10 since one year now and last month my other colleagues migrated too. Now one colleague told me, when he edits a dialog, the new control is present in resource.h but not in resource.fd. When he wants to use the control (dlgset ...) it wont compile because it is not listed in resource.fd.
Im working ata project over a year now, edited the dialogs a lot and never experienced such behaviour. So I tested this in another project I working with, where I havent changed the dialog since. To my surprise, in the second project, a new control is not present in resource.fd, but in resource.h. In the first project everything works fine, when I add new controls.
Both projects where originally written in CVF and where migrated to IVF. We are using VS2008 Professional on WindowsXP German.
Thanks in advance,
Markus
It sounds like the resource.fd is not being recreated automatically by your resource compilerin response to changes made to the .RC or .RES files. This happens automatically with CVF. I believe that IVF needs the VC++Resource compiler? Perhaps your VC++ integration has a bug? Have you manually edited the .RC or .RES files at anytime? If so, that is NOT recommended otherwise resource problems result.
You could try deleting the present .FD file and see what happens when you recompile the .RC file.
When I delete both resource.fd files, the working project creates a new resource.fd, while compiling. The other wont. Compiling script.rc manually doesnt help.
I compared theResources entries in Project -> Properties and they are identical. I compared both script.rc and they dont have any differences (except the controls of course).
So somehow my project wont create or update the resource.fd, but why?
Markus
I did a Google search using "resource.fd not updated from resource.h" and found this link.
http://software.intel.com/en-us/forums//topic/53748
The bit I think you will find useful is the following (from Jugoslav Djugic, as usual!)
Quote:"As for "resource.fd", it is semi-automatically "translated" from resource.h by Intel-provided tool called deftofd. The "semi-automation" is achieved by a custom build rule on the resource.h property sheet. The build rule is created if you create the project from File/New/Project or if you converted it from CVF project; otherwise, you have to add it manually, for all configurations. The build rule is universal and it reads:
Command line: deftofd "$(InputPath)" "$(InputDir)$(InputName).fd"
Description: Generating Fortran include file...
Outputs: $(InputDir)$(InputName).fd
It possibly got lost during your cleanup attempts; basically, you don't need the backup of resource.fd. " Unquote
- Add Resource.h to your project using File>Add Existing Item...
- Select the Resource.h file in the Solution View and the select View>Property Pages from the main menu bar.
- Set the Command Line option to use the deftofd tool by entering:
deftofd resource.h resource.fd
(For more information on the deftofd tool, see The Include (.FD and .H) Files.) - Set the Description option to Generating Fortran include file...
- Set the Outputs option to resource.fd.
- Click OK.
Thanks for the link, now it works!
Markus
I had followed these 6 steps you wrote, but got no result.
A file "resource.fd" was not created from "resource.h".
Any sugestion how to fix it?
Is there any other way to create an *.fd file from *.h file?
