29341 Discussions
Convenience libraries, ipo, and unresolved references
Jack_S_1
I am attempting to recompile code that was written using GNU tools, including autotools. In the makefiles, I make a lot of use of so-called convenience libraries, or local static libraries that are only used as compilation stages, and which are not installed. This is a fairly common practice with autotools, but doing so leads to unresolved references at link time when -ipo is specified on the command line. If I don't use -ipo, everything is fine. The problem only occurs with -ipo.
Is there an easy workaround that does not involve removing the convenience libraries?
TimP
If you use e.g. ar to make those libraries you switch to xiar to support ipo
TimP
Jack_S_1
Yep, that worked. Thanks.
