29564 Discussions
compilervars.sh destabilizes my linux environment
Philip_G_
I have tried to install Intel Composer XE 2015.0.090 in both OpenSuse 13.1 and Ubuntu 14.04 LTS environments. In both cases I have followed the instructions here (https://software.intel.com/en-us/articles/using-intel-compilers-for-linux-with-ubuntu)  and installed the compilers for 64bit system only.
When I add the
source /opt/intel/bin/compilervars.sh intel64
command to my ~/.bashrc file, it causes the system to fail to re-boot (under both OS) next time I try to log in. Even typing the source command in a terminal window (i.e. not adding the command to my .bashrc file) causes the system to fail at next login.
In Ubuntu, the boot process is now stuck at the "lubuntu" screen with 5 dots endlessly recycling.
I must be doing something wrong with my installation, but I have no idea what - can anybody help ?
