- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Unformatted Sequential file as follows:
IMPLICIT REAL*8(A-H,O-Z)
DIMENSION R(4,80,6,46)
OPEN (UNIT=11, ERR=998, STATUS='OLD',
ACCESS='SEQUENTIAL', FORM='UNFORMATTED', IOSTAT=IERRA, FILE='water')
READ(UNIT=11, IOSTAT=IERRA) R
According to this post's illustration, http://origin-software.intel.com/en-us/forums/showthread.php?t=45634
I am modify this program as follows:
IPRNT = 4
OPEN(UNIT=11,ERR=998,STATUS='OLD',ACCESS='SEQUENTIAL',
FORM='binary',convert='VAXD',FILE='water')
open(unit=iprnt,ERR=998, status='replace',IOSTAT=IERRA,file='wdise.TXT')!
I meta problem when Idebug the program ,the prolem is:"forrtl: info(95) floating point conversion failed".
So confused I am, Would you please give me some advice to solve this problem ,Thanks.
David.wan
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I attach a small program which I have written to process the 2044 blocks to create a new binary file with 2042-byte records. This new binary file is then read to recreate the REAL*8 array. The program does no conversion of the data. It assumes that the ASCII code used in the file matches that used by windows and that the byte data are arranged MSB first, LSB last, i.e. if a number starts at byte N, byte N is assumed to be the MSB and byte N+7 is assumed to be the LSB. In a data record, byte N is to the left of byte N+1 and subsequent bytes.
The program should be run in debug mode so that you can examine the content of the Real array R when the program reaches the PAUSE, to see if they make sense to you (assuming you have some idea of what magnitudes the numbers should be). Note that there is only enough data in the file to create an array of values of dimension (4,80,6,37).
I attach the program for you to do with as you wish.
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Does the program read any of the data correctly?
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Ok,Maybe I need to find another way to solve this problems
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Here's an article I wrote on this many years ago, and I've attached the programs it mentions. Perhaps this will be helpful to you.
Description: Unlike FORMATTED files, Fortran SEQUENTIAL UNFORMATTED files vary in data layout among various compiler vendors and platforms. This article summarizes how to read UNFORMATTED files from various combinations of compilers and platforms.
The Visual Fortran SEQUENTIAL UNFORMATTED file layout is one that is very common on UNIX systems, including DIGITAL UNIX. Each Fortran "record" is preceded and followed by a 32-bit integer containing the record length (the integer is stored in the "little-endian" layout, with the least-significant bit in the lowest addressed byte.) This record length is required to apply Fortran record semantics, including the ability to use BACKSPACE. Unfortunately, this is not correctly documented in the Programmer's Guide - the layout described there is actually that of Microsoft Fortran PowerStation. This will be corrected in future editions.
DIRECT UNFORMATTED files do not typically have embedded record length information and can usually be read/written without special actions.
- Microsoft Fortran (including Fortran PowerStation and Fortran 5.x for DOS)
- These files can be read (and written) directly by enabling the /fpscomp:ioformat switch (Compatibility..PowerStation..I/O Format setting). Note that this is the default if you use the FL32 command from a command prompt.
- DIGITAL Fortran for DIGITAL UNIX
- These files can be read and written directly with no special actions.
- Other UNIX systems
- For HP, IBM, Sun, SGI and other big-endian UNIX systems, open the file with the CONVERT='BIG_ENDIAN' option. For little-endian UNIX systems (such as Linux on X86 processors), no special action is typically needed.
- DIGITAL Fortran for OpenVMS
- The default SEQUENTIAL UNFORMATTED file layout on OpenVMS
is called 'SEGMENTED'. A logical record may be split
across multiple physical records - each has a 16-bit prefix
of flags indicating whether that physical record is the
first, last middle or only in the logical record.
While Visual Fortran CAN read these, if the file is opened
with RECORDTYPE='SEGMENTED', in practice this is difficult
because you must transfer the data in such a way as to preserve
the file system's record lengths, and typical methods such
as FTP remove this information.
One way is to use a program on the OpenVMS system to convert the file to a format which can be easily transferred and read by Visual Fortran. To convert an OpenVMS 'SEGMENTED' file to a form which can be read by Visual Fortran, use segmented_to_unix.for (note that the Visual Fortran layout is the same as is used by UNIX systems). To convert a Visual Fortran file so that it may be read by Fortran on OpenVMS, use unix_to_segmented.for.
Another way is to prepare a SEGMENTED file for transfer by changing the file's recordtype to be fixed-length, 512 byte records, using the command:
$ SET FILE /ATTRIBUTES=(RFM=FIX,LRL=512) file.dat
This file can then be copied to the Windows system using normal FTP in binary mode. On the Windows system, open the file using RECORDTYPE='SEGMENTED'. This method cannot be used for files that were opened with RECORDTYPE='VARIABLE' explicitly specified.
If the file contains floating data and was written on a VAX or on an Alpha system with the default VAX floating types, you will need to specify CONVERT='VAXD' or 'VAXG' (as appropriate) when opening the file using Visual Fortran. This will automatically convert the data in scalars and arrays (though not in RECORD structures or derived types.)
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
To hold the contents of the array R, with the declared dimensions of (4,80,6,46) would require (4 X 80 X 6 X 46)numbers X 8 bytes/number = 706560 bytes, plus any record length and header bytes. The data file "water" that you attached contains 584252 bytes, which amounts to not even 7 bytes per double precision real.
There is something inconsistent here.
Secondly, until one gets things to work properly, in cases like this it would be better not to include ERR= and IOSTAT= options in READ statements -- let the system tell you the errors it runs into while trying to read the file.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Steve,Thanks for your help. I compiletheprogram (segmented_to_unix.for) using Compaq Visual Fortran 6.60 on my PC ,but it occuringa lot of problem.Therefore,Ihave a question. Whether the program must be run in the VAX computer ? not in PC, and how to use the command in CVF, '$ SET FILE /ATTRIBUTES=(RFM=FIX,LRL=512) file.dat', thanks.
Anyway,we can't find the vax computer easily, so other solutions could befound ?
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Oh,bad luck, and I am using RECORDTYPE='FIXED' to convertthe file ,however, itcan'tberead.
So, how I can solve this problem? Does some onein the same situation ? Thanks all the same ,steve.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
The array you are reading is a REAL*8 dimensioned (4,80,6,46). Taking the first two dimensions and multiplying, you get 4*80*8=2560 bytes. dividing by 16 gives 160 decimal, or A0 hexadecimal. If you open the file as binary (i.e. not auto) in the VS editor, you will soon see that the following repeats every 160 lines (or A0 hex), assuming 16 bytes per line displayed:
00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 80 40 00 00 00 00 00 00 00 00 00 00 00 00
00 00 7F 40
Using this flag, you can at least isolate groups of 320 real values. Clearly there should be 6*46 = 276 such groups. This indicates that the array was almost certainly written in column major order starting with the first index and writing the data as sets of 2-dimensional arrays.
Within each group, the first index should vary fastest, so there should be natural groups of 4*8 bytes (possibly with spacer bytes).
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Especially, "Within each group, the first index should vary fastest",how can I realize this function?
So, Could you pleaseprovideme some specificsolutions?And I can obtain this data accurately . Thank you.
Best wishes to you.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
If, as the file name suggests. it contains some properties of water, it should be easy to recreate it ab initio . Software for calculating these properties is widely available.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
solution for this problem.
