29429 Discussions
Copy extended types gives access violation
Lars_Jakobsen
Hi
I get an access violation when I try to copy one extended structure to another:
"forrtl: severe (157): Program Exception - access violation"
If I use ordinary "types", then this works fine.
Am I not allowed to copy one extended type to another? Is there are workaround?
I am using the Intel Visual Fortran Compiler v. 16.0.
    program Console1
    implicit none
    ! Variables
    integer, parameter :: DP=8
    integer, parameter :: MAXNAMELENGTH=10
!-- BASIC TYPE
    type :: T_BASIC(n)
      integer, len                    :: n=MAXNAMELENGTH  !length of nam (defaults to MAXNAMELENGTH)
      character(len=n)                :: nam    !name
      integer                         :: iPoi   !internal pointer
    end type T_BASIC
!-- beam appurtenance properties
    type, extends(T_BASIC) :: T_prtapp    !<- **** this will lead to trouble ****
!    type :: T_prtapp                     !<- **** this will work            ****
      integer                                         :: Tp
    end type T_prtapp
!-- beam appurtenances (actual appurtenances as used)
    type :: T_bapp
      type (T_prtapp)                                 :: prt     !appurtenance properties for this beam appurtenance
    end type T_bapp
!-- Global data
    type :: T_G
      type(T_prtapp), dimension(:), allocatable         :: prtapp  !appurtenance properties
      integer                                           :: nprtapp !number of appurtenance properties
      type(T_bapp), dimension(:), allocatable           :: Bapp     !beam appurtenances
      integer                                           :: nBApp    !number of beam appurtenances
    end type T_G
    type(T_G) :: G
    integer   :: iret
    ! Body of Console1
    G%nprtapp = 5
    allocate(G%prtapp(G%nprtapp))
    G%nBapp = 3
    allocate(G%Bapp(G%nBapp))
    G%Bapp(1)%prt = G%prtapp(1)   !<- this throws the error
    iret = 1
    end program Console1
Best regards
Lars
I can reproduce this in 16.0.3 but not in the current version 17.0.0. Please upgrade.
Andrew_Smith
Valued Contributor I
I was able to create default assignment code to make it work. But the area of parameterized derived types has been problematic and if Steve says use latest compiler then it certainly is good advice.
module myType
   implicit none
   type :: T_BASIC(n)
      integer          :: iPoi
   end type
      integer             :: Tp
   end type
   type :: T_bapp
   end type
   type :: T_G
     integer                                   :: nprtapp
     integer                                   :: nBApp
   end type
   interface assignment(=)
      module procedure assignT_Basic
      module procedure assignT_prtapp
   end interface
contains
   elemental subroutine assignT_Basic(b, a)
      type(T_Basic(*)), intent(in) :: a
      type(T_Basic(*)), intent(inout) :: b
      b%nam = a%nam
      b%iPoi = a%iPoi
   end
   elemental subroutine assignT_prtapp(b, a)
      type(T_prtapp), intent(in) :: a
      type(T_prtapp), intent(inout) :: b
      b%T_Basic = a%T_Basic
      b%Tp = a%Tp
   end
end module
program Console1
   use myType
   implicit none
   type(T_G) :: G
   integer   :: iret
   G%nprtapp = 5
   G%nBapp = 3
   G%Bapp(1)%prt = G%prtapp(1)   !<- this now works
   iret = 1
end program
Lars_Jakobsen
I have upgraded to version 17 and it now seem to work.
Thank you both for the quick response.
Lars
