Crash if temporary implicit pointer is created
Marat_S_1
Could you please explain the crash in the following program?
[fortran]
module A_m
  implicit none
  private
  type, public :: A_t
    private
    character(len=1)  :: dummy_char
  contains
    procedure :: DoSmth
  end type
contains
  subroutine DoSmth(this)
    class(A_t), intent(in) :: this
    write(*, "(A)") "A_t::DoSmth"
  end subroutine DoSmth
end module A_m
module B_m
  use A_m
  implicit none
  private
  type, public :: B_t
    private
    class(A_t), pointer :: a => null()
  contains
    procedure :: GetA
    procedure :: SetA
  end type
contains
  subroutine SetA(this, a)
    class(B_t), intent(inout)         :: this
    class(A_t), pointer, intent(in)   :: a
    this%a => a
  end subroutine SetA
  function GetA(this) result(a)
    class(B_t), target, intent(in) :: this
    a => this%a
  end function GetA
end module B_m
program main
  use A_m
  use B_m
  implicit none
  class(B_t), pointer :: b
  class(A_t), pointer :: a_ptr
  allocate(a, b)
  call b%SetA(a)
  ! works with explicit pointer
  a_ptr => b%GetA()
  call DoA(a_ptr)
  ! crashes here
  call DoA(b%GetA())
  deallocate(a, b)
contains
  subroutine DoA(a)
    if (.not.associated(a)) then
      write(*, "(A)") "error"
    else
      call a%DoSmth()
    end if
  end subroutine DoA
end program main
[/fortran]
I believe that the program crashes because an implicit pointer is created at the statement "call DoA(b%GetA())".
Compiler version: XE 13.1
Steven_L_Intel1
I am looking at this now.
