write huge
Marat_S_1
I just have a quick question.
This simple program
[fortran]
program WriteHuge
  implicit none
  print *, huge(0.0d0)
  write(*, *) huge(0.0d0)
  write(*, '(E24.16)') huge(0.0d0)
  write(*, '(E40.20)') huge(0.0d0)
end program WriteHuge
[/fortran]
prints to the console
[fortran]
  1.797693134862316E+308
  0.1797693134862316+309
              0.17976931348623157081+309
[/fortran]
Why there is no 'E' in the last two lines? Is something wrong with the format?
Compiler version: XE 13.1
Les_Neilson
Valued Contributor II
For an explicit format if the value of the exponent is    99 < |exp| < 999   then the E is omitted. (see the help re: format specifications E and D editing)
"print *"  means "list directed format" (basically the compiler can choose the format)
Les
Les_Neilson
Les
TimP
In order to see the E field when a 3-digit exponent appears, you must specify explicitly a wider exponent field.  The default was set up so that 3-digit exponents would not consume more space in formats set up for 2-digit exponent values.
Marat_S_1
Thank you.
