29487 Discussions
replacement of fortran loops by memcpy
Matthieu_B_
I face some difficulties with some optimizations performed by the ifort compiler.
If i write this subroutine : [fortran]
      subroutine zmv (ia,ib,n)
C-------------------------------------------------------------------
C            move the content of a table to another
C            ib should be left of ia in memory
      integer   ia(*),ib(*),i,n
C
      do i=1,N
        ib(i)=ia(i)
      enddo
      return
      end
[/fortran]
The thing is that using O3 option, ifort will replace my loop by a intel_fast_memcpy while nothing prevent me from doing this :  [fortran]
      program test
      implicit none
      integer i,n
      parameter (n=10)
      integer Z(n)
c     Initialize the content of the array
      do i=1,10
        Z(i) = i
      enddo
c     Move the 6 to 10th value to the 3rd to 7th
      call zmv(Z(6),Z(3),5)
c     Print the result
      write(*,'(99g)')(Z(i),i=1,n)
      end
[/fortran]
As one can see, in the zmv subroutine call, the ia and ib array are overlapping (ib being left of ia). In this case, according to the C documentation, and as seen in a much more complicated exemple, nothing guarantee me that the copy will be correctly performed. A much safer way would have been to use memmove.
So I was wondering why ifort does this? Is my call to zmv subroutine somehow not compliant with fortran standard?
Your program is not standards-compliant. zmv by itself is ok, but when combined with the call that causes overlap of the ia and ib arguments, you violate the rules against dummy aliasing. You could try compiling with -assume dummy_alias - that should disable this optimization.
