Cray Integer Pointer Rank2 array?
Darrell
The Intel Fortran documentation on Mixed Language Programming, Handling Integer Pointers shows an example C++ program calling Fortran passing in a 1 dimensional array. How do I specify a 2-dimensional array? Starting with the following 1D example that seems to work:
integer ptr
real, dimension(*) :: data
pointer(ptr, data)
The F90 pointer code had dimension(:,:) but the compiler doesn't like that any more if I understand the error message below:
Error: If a deferred-shape array is intended, then the ALLOCATABLE or POINTER attribute is missing; if an assumed-shape array is intended, the array must be a dummy argument.
Is it possible to Reshape or Equivilance? Is there a book Dummy Arguments for Dummies? :-)
Current project requirements are preventing me from using F90 pointers or Fortran 2003 ISO_C_BINDING. I feel like I'm trapped in 1978, I'm starting to hear disco music! I could have bought new compilers for everyone in the time wasted on this. Thanks for all your help!
You can explicitly dimenion the array, such as (10,20), but you can't use (:.:) (which implies that a descriptor was passed) nor (*,*), as the compiler would have no idea how to index the array. You can do (10,*) or the like. You can't EQUIVALENCE a Cray pointee and can't RESHAPE an assumed-size array.
