29413 Discussions
idb did not install with ifort evaluation
Mike_Mills
I've just installed a 30-day evaluation of ifort 11.1 for Mac OS X, and the debugger idb is missing. I tried also installing the C compiler, but that also is missing the idb debugger. How do I go about evaluating the debugger? I am running Mac OS 10.6.
Ron_Green
idb should be installed in /opt/intel/Compiler/11.1//bin/idb
Did you:
source /opt/intel/Compiler/11.1/058/bin/ifortvars.sh intel64 [or ia32 if you have an older 32bit Mac]
so that your paths are set up properly?
ron
Mike_Mills
Did you:
ron
I do not have idb in that path, nor in the subpaths intel64 and ia32. I have sourced the intel64/ifortvars.sh so that my path is set up properly.See shell session below:
Tillamook:~ 500$ cd /opt/intel/Compiler/11.1/058/bin/
Tillamook:bin 501$ ls
ia32 iccvars.sh ifortvars.sh
iccvars.csh ifortvars.csh intel64
Tillamook:bin 502$ cd intel64
Tillamook:intel64 503$ ls
codecov icpc.cfg profmerge
codecov_libFNP.dylib icpc_libFNP.dylib proforder
fortcom ifort svcpcom
fpp ifort.cfg svfortcom
icc ifort_libFNP.dylib tselect
icc.cfg ifortvars_intel64.csh tselect_libFNP.dylib
icc_libFNP.dylib ifortvars_intel64.sh xiar
iccvars_intel64.csh mcpcom xild
iccvars_intel64.sh prelink xilibtool
icpc profdcg
Tillamook:intel64 504$ pwd
/opt/intel/Compiler/11.1/058/bin/intel64
Tillamook:intel64 505$ cd ../ia32/
Tillamook:ia32 506$ ls
icc.cfg ifortvars_ia32.csh tselect_libFNP.dylib
icc_libFNP.dylib ifortvars_ia32.sh xiar
iccvars_ia32.csh mcpcom xild
iccvars_ia32.sh prelink xilibtool
icpc profdcg
Tillamook:ia32 507$ which idb
Tillamook:ia32 508$ echo $PATH
.:/Users/mills/usr/local/bin:/Volumes/Data/Libraries/mpich/bin:/Users/mills/usr/ncl/bin:/Volumes/Data/Libraries/netcdf/bin:/opt/intel/Compiler/11.1/058/bin/intel64:/opt/local/bin:/opt/local/sbin:/sw/bin:/sw/sbin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/X11/bin:/usr/X11R6/bin:/Applications/itt/idl/bin
Would it affect the installation that I have a licensed copy of 10.1.014 installed? I wouldn't think so. I do have that version of idb in/opt/intel/idbe/10.1.014/bin
Mike_Mills
I just tried moving the whole /opt/intel directory to /opt/intel2, then reinstalled ifort. It created a new /opt/intel directory, but I still do not have idb.
Ron_Green
Quoting - Mike Mills
Mike,
I apologize, I just now noticed that you are running Snow Leopard. Intel won't support Snow Leopard until we release our next version of the 11.1 compiler. This will occur sometime around mid-September.
It would be helpful to know the hardware specifics for your Mac. Is this an iMac, Mac Pro, MacBook or MacBook Pro? If iMac, approximately when did you purchase the computer? What processor name, and what processor speed (from 'About this Mac' from the Apple Menu)
Oh, and did you do a standard installation or a custom installation?
thanks
ron
Mike_Mills
Thanks, Ron. I'm running on a 2009 Mac Pro with 2 x 2.93 GHz Quad-Core Intel Xeon "Nehalem" processors. I did a standard installation for ifort and C++. I looked at the custom installation options, but didn't see anything additional that could be added.
Quoc-An_L_Intel
What are you getting as a return value for the command: "sysctl hw.cpufamily", as well as "sysctl hw.machine"?
An
Mike_Mills
Quoting - Qale (Intel)
An
hw.cpufamily: 1801080018
hw.machine: i386
Ron_Green
hw.machine: i386
Mike,
We are investigating this on our Mac Pro Nehalem system.
Hopefully this is the last question we'll ask: are you using a released version of Snow Leopard or a beta version?
Sorry to keep dragging this on, but we'd like to fully understand the environment you have. It will help us and help other users.
ron
Mike_Mills
No problem, Ron. I'm happy to answer any questions you have to help sort this out.
I'm using the released version of Snow Leopard.
Quoc-An_L_Intel
This is a known problem, and it will be fixed in the next update. Thanks for notifying us.
http://software.intel.com/en-us/articles/intelr-debugger-failed-to-install-on-mac-pro-with-quad-core-intel-xeon-processor/
In the mean time, if you want a work around,
1) mount the image .dmg file
2) copy directory /Volumes/m_cprof_p_11.1.058/m_cproc_p_11.1.058.mpkg to a local directory
3) modify m_cprof_p_11.1.058.mpkg/Contents/distribution.dist to check for Nehalem signature Line #210 (see red below)
4) double click on the local m_cprof_p_11.1.058.mpkg and restart the installation
function determine_Arch32_64() {
var result = false;
try {
// this next line checks for the intel64 bit cpufamily
result = system.sysctl('hw.cpufamily');
if(result == 1114597871 || result == 2028621756 || result == 1943433984 || result == 1801080018) {
result = true;
else {
result = false;
} catch (e) {}
return result;
