Create a Fortran DLL?
PlettB
I have the simplest example I can think of:
! minimal_example.f90
function add_numbers(a, b) bind(C, name="add_numbers")
  integer, intent(in) :: a, b
  integer :: add_numbers
  add_numbers = a + b
end function add_numbers
I compile this using:
ifx.exe -dll -o minimal_example.dll minimal_example.f90
I then try:
dumpbin /exports minimal_example.dll
I get:
Microsoft (R) COFF/PE Dumper Version 14.42.34435.0
Copyright (C) Microsoft Corporation.  All rights reserved.
Dump of file minimal_example.dll
File Type: DLL
  Summary
        1000 .data
        1000 .pdata
        1000 .rdata
        1000 .reloc
        1000 .text
No sign of "add_numbers".  What gives?
P.S. I also tried "ifort" with the same results.
PlettB
Ugh! I should never have posted this. Just a few more minutes of research and I have it working!
In case anyone else looks to this thread for help, this solved my issue:
integer, value, intent(in) :: a, b
PlettB
I guess I posted that too quickly!  I found I needed to add:
!DEC$ ATTRIBUTES DLLEXPORT::add_numbers
However, now that I've done that, I'm trying the following P/Invoke declaration:
        [DllImport("minimal_example.dll", CallingConvention = CallingConvention.Cdecl)]
        public static extern int add_numbers(int a, int b);
And I'm getting:
System.AccessViolationException: Attempted to read or write protected memory.
Any ideas?
PlettB
