Creating a zipped file or folder
sumitm
I am trying to create a zip file from a group of files.
I do not want to use 3rd part software but native xp/vista zipfldr.dll option or any other. I am trying to avoid making a .cab file.
Is there a way to run that from inside IVF including using SYSTEMQQ or any other option
What I wish to do is
rundll32 zipfldr.dll outputfileorfolder.zip *.ext
The first two arguments is what I am looking for
Thanks for any options
Sumit
This MSDN Forum thread asks the same thing. Apparently, there is no way to do it quite as you're asking. The thread suggests that there is a way to call the shell's COM interface to do it, which would theoretically be possible from Fortran using the Module Wizard. If I understand the code correctly, one creates an empty ZIP file (you can do this with stream I/O in Fortran) and then asks the Shell to copy files into it.
joerg_kuthe
Hi Sumit,
in case you change your mind, search for ZLIB in this forum and you finda simple way to create a .zip file.
Joerg
