Creating bitmap in color
Tomas750
I have tried to fill bitmap created by function CreateDIBSection with some graph (lines and shapes of various colors). Although 24 bits for colors are declared there, only four distinct colors were finally found when using the function GetDIBits for retrieving the bitmap. The rest is changed into white. What is wrong?
Paul_Curtis
Valued Contributor I
You would need to post your code before anyone can try to help you with this.
Tomas750
integer*4 hdcBits, cClrBits
integer*4 nBitmapWidth, nBitmapHeight
integer*4 hBitmap, hOldBitmap ! bitmap handle
integer(1), ALLOCATABLE:: lpBits(:)
integer(1), ALLOCATABLE:: lpBitsCompr(:)
pointer (p, pbmi)
type (T_BITMAPINFO) pbmi
cClrBits = 24
nMem = SizeOf(pbmi%bmiHeader)
p = LocalAlloc(LPTR, nMem)
! Prepare BITMAPINFO for the bitmap
pbmi%bmiHeader%biSize = SizeOf(pbmi%bmiHeader)
pbmi%bmiHeader%biWidth = nBitmapWidth
pbmi%bmiHeader%biHeight = nBitmapHeight
pbmi%bmiHeader%biPlanes = 1
pbmi%bmiHeader%biBitCount = cClrBits
pbmi%bmiHeader%biCompression = BI_RGB
pbmi%bmiHeader%biSizeImage = IAND(pbmi%bmiHeader%biWidth * cClrBits + 31, INOT(31))/8 * pbmi%bmiHeader%biHeight
pbmi%bmiHeader%biXPelsPerMeter = 0
pbmi%bmiHeader%biYPelsPerMeter = 0
pbmi%bmiHeader%biClrUsed = 0
if (cClrBits < 16) pbmi%bmiHeader%biClrUsed = 2**cClrBits
pbmi%bmiHeader%biClrImportant = 0
ALLOCATE(lpBits(pbmi%bmiHeader%biSizeImage), STAT=AllocErr)
if (AllocErr == 0) then
hBitmap = CreateDIBSection(hDC, pbmi, DIB_RGB_COLORS, LOC(lpBits), 0, 0)
hdcBits = CreateCompatibleDC(hDC)
hOldBitmap = SelectObject(hdcBits, hBitmap)
! Prepare the bitmap by painting the spectrum
call CfPrBMP(hdcBits, nBitmapWidth, nBitmapHeight)
! Replace a new object with the original, default object
i = SelectObject(hdcBits, hOldBitmap)
! Retrieve the color table (RGBQUAD array) and the bits (array of palette indices) from the DIB.
nScan = GetDIBits(hdcBits, hBitmap, 0, pbmi%bmiHeader%biHeight, loc(lpBits), loc(pbmi), DIB_RGB_COLORS)
end if
Paul_Curtis
Take a look at the arguments for calling GetDIBits; according to MS,
"If lpvBits is NULL and the bit count member of BITMAPINFO is initialized to zero, GetDIBits fills in a BITMAPINFOHEADER structure or BITMAPCOREHEADER without the color table. This technique can be used to query bitmap attributes."
So if you call with null values [ie, GetDIBits (hdc, hbitmap, 0, 0, 0, LOC(bitmapInfo), DIB_RGB_COLORS)] the colormap properties are returned in the info header structure.
