29649 Discussions
Curiosity - File Content Determination?
Intel_C_Intel
I have some FORTRAN code that opens a file with FORM = 'FORMATTED', STATUS = 'UNKNOWN', RECL = 1024, CARRIAGECONTROL = 'LIST'. I write out some formatted records.
I can open my file in Notepad, which seems happy that the content it text (or at least, can be displayed as text).
If I use DevStudio to try to open the file, specifying the type as Text, DevStudio claims the file is binary and won't open it (it will open it as binary).
If I then open the file in Notepad, save it and close it, I can then open it in DevStudio as text.
I checked and the file does not change size in any way, even by a byte. So how does DevStudio determine the type of the contents of a file? And why does it 'get it wrong'?
Of course, Notepad is probably displaying a binary file as text (as it always tries to do), it just so happens that the binary is text...
My recollection is that DevStudio looks to see if there non-printing characters in the file. I'd want to see the actual file (before NOTEPAD) before commenting further - can you attach a ZIP archive of an example?
Steve
Intel_C_Intel
Steve, you're right, my original file has some NULL characters in it, which are replaced with spaces when saved from notepad. Seems odd because they result from the line:
WRITE (filun, 1000) in_field
where
1000 FORMAT (6(A,','))
(in_field is a CHARACTER*16 array, width = 18)
The same formatting line is used elsewhere and does not output NULLs. E.g.:
WRITE (filun, 1000) in_unit
where in_unit is a CHARACTER*10 array).
