Some time ago I used Matlab to display the closed surface ( similar to a zeppelin ) of the radiation pattern envelope of microwave antennas. Matlab has the MESH(X,Y,Z) command to do that. X, Y and Z are vectors composed using the RPE of the antenna.
I want to make the same kind of display using Fortran, and tried to use the Array Viewer. In all samples I found, the surfaces displayed are not closed, and found nothing about in help. Can it be done with the Array Viewer ?
Trying to do it using the graphic routines of QwickWin will be very hard, kind of reinventing the wheel.
Thanks for any hint
Cacciatore
Thanks for any hint
Cacciatore
Sorry, the Compaq Array Viewer can only display surfaces that don't close back on themselves. i.e. z = f(x, y).
We've been thinking of adding a new plot type to display closed surfaces for the next release of the Intel Array Visualizer. It sounds like this would be a useful feature.
In Matlab does the Mesh routine take just a collection of points in x,y,z space? The points without any connection information don't define the surface, but I suppose Matlab has an algorithm that creates a surface based on the most "natural" shape.
John
John
I do not know how Matlab realy does it. I just make a projection of a vector (with origin in 0,0,0 and end in a point in the surface), in each of the axis, and put each projection in a x , y and z vector. So those vectors have the same size, and each element with the same index refers to a particular point in the surface. The mesh(x,y,z) draws the grid joining adjacent points.
I will use a mixed aproach, generating the x, y and z vectors using fortran, writing then to a txt file, opening Matlab with runqq, and once there running an Matlab exec that reads the vectors and mesh then.
It may be awkwards but I only want to see if the algoritm I will use to compose the 3D RPE is ok.
Geraldo Cacciatore
Geraldo Cacciatore
