DLL Dependency problem
Fleck__Guenter
I have recently switched to new version of Fortran compiler Dependencies after Building a dll is correctly in the following example Release Build.
When changing w= 0. into w=1. there is an additional amount of needed DLL's (could be seen e.g. in the dependency walker) Why is this? Can you please help me with this issue.
Best Regards
Gnter
Minimal example:
SUBROUTINE cwert1(wv)
implicit none
integer v
real w
real :: wv
character*1 zeichen
v = 1
w= 0.
zeichen='-'
select case (zeichen)
case ('-')
v = -1
end select
wv = v*w
end
Microsoft Visual Studio 2010
Version 10.0.40219.1 SP1Rel
Microsoft .NET Framework
Version 4.0.30319 SP1Rel Installed Version: Professional Microsoft Office Developer Tools 01018-532-2002163-70123
Microsoft Visual Basic 2010 01018-532-2002163-70123
Microsoft Visual C# 2010 01018-532-2002163-70123
Microsoft Visual C++ 2010 01018-532-2002163-70123
Microsoft Visual F# 2010 01018-532-2002163-70123
Microsoft Visual Studio 2010 Team Explorer 01018-532-2002163-70123
Microsoft Visual Web Developer 2010 01018-532-2002163-70123
Crystal Reports Templates for Microsoft Visual Studio 2010 Intel Visual Fortran Package ID: w_fcompxe_2011.7.258
Intel Visual Fortran Composer XE 2011 Update 7 Integration for Microsoft Visual Studio* 2010, 12.1.3518.2010, Copyright (C) 2002-2011 Intel Corporation
Intel C++ Composer XE 2011 Update 7 Package ID: w_ccompxe_2011.7.258
Intel C++ Composer XE 2011 Update 7 Integration for Microsoft Visual Studio* 2010, Version 12.1.1104.2010, Copyright 2002-2011 Intel Corporation
Intel Inspector XE 2011 Update 7
Intel Inspector XE 2011 Update 7, (build 189290), Copyright 2009-2011 Intel Corporation. All rights reserved. Intel VTune Amplifier XE 2011 Update 5
Intel VTune Amplifier XE 2011 Update 5, (build 186533), Copyright 2009-2011 Intel Corporation. All rights reserved.
Les_Neilson
Valued Contributor II
Given the code you have shown, it is possible that the optimiser is reducing the whole of thesubroutine to simply wv = 0.0 (since w = 0.0 irrespective of any value for v).
But I would have expected a similaroptimisation for w=1.0 to produce wv = -1.0 since the compiler can determine that (a) zeichen is always '-' therfore (b) v is always -1 therefore (c) wv is always -1.0
How this affects the dlls I don't know.
Les
Fleck__Guenter
Thank you for your quick reply. I posted a minimal Example. In the original code this optimization is not possible.
I switched the optimization Level to Disable (/Od). I have the same problem...
Gnter
Here is what I see.
At /Od, there is no difference in the required DLLs between the two cases. Both make a call to a Fortran library routine _for_cpstr to handle the assignment to zeichen. Whether 0 or 1 is assigned to w makes no difference. This routine call is what pulls in the Fortran run-time DLLs.
With standard optimization, the compiler sees that for the w=0 case that wv will always be set to 0, so it removes everything else. For w=1, while it could, theoretically, notice that v will always be -1, it doesn't do so, so it generates the code to assign to zeichen and do the SELECT CASE.
heribertreiser
Hi
I am working with guenter together.
It is possible to change w=1, if you remark the line v=-1 (!v=-1).
You just need the usual runtimes (no libif-runtimes needed).
Same when you uncomment v=-1 and remark wv = v*w (!wv = v*w).
implicit none
integer v
real w
real :: wv
character*1 zeichen
v = 1
w= 1.
zeichen='-'
! select case (zeichen)
! case ('-')
v = -1
! end select
wv = v*w
end
This is working too :
implicit none
integer v
real w
real :: wv
character*1 zeichen
v = 1
w= 1.
zeichen='-'
! case ('-')
v = -1
! end select
wv = v*w
wv=ichar(zeichen)
v=ichar(zeichen)
end
There are no runtimes needed. Same Here :
implicit none
integer v
real w
real :: wv
character*1 zeichen
v = 1
w= 1.
zeichen='-'
case ('-')
v = -1
end select
wv = v*w
wv=ichar(zeichen)
v=ichar(zeichen)
end
But whats not working (meaning a bunch of runtimes needed):
implicit none
integer v
real w
real :: wv
character*1 zeichen
v = 1
w= 1.
zeichen='-'
case ('-')
v = -1
end select
wv = v*w
! wv=ichar(zeichen)
! v=ichar(zeichen)
end
