The following code generates an internal compiler error:
program TestCommonImport
implicit none
!DEC$ ATTRIBUTES DLLIMPORT :: / abc /
common / abc / x, xa
real x, xa(10)
x = xa(1) ! This is OK
xa(1) = 1.0 ! Generates "internal compiler error"
end program TestCommonImport
implicit none
real x, xa(10)
The problem occurs when assigning a value to an array element that is a member of a common block imported from another DLL. The "buildlog.txt" is
------ Build started: Project: TestCommonImport, Configuration: Debug|Win32 ------
Deleting intermediate files and output files for project 'TestCommonImport', configuration 'Debug|Win32'.
Compiling...
ifort /nologo /Zi /Od /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:static /dbglibs /c c:srcTestCommonImportTestCommonImport.f90
0_1104
Compiling...
0_1104
Severe: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
in file (null), line 0, column 0
compilation aborted for c:srcTestCommonImportTestCommonImport.f90 (code 3)
TestCommonImport build failed.
Is this a known problem?
Thanks and Regards,
David
You didn't say what version you are using. It works for me in 8.0.050.
Please note that this is NOT the place to report suspected compiler bugs. For that, please use https://premier.intel.com/
