Communicate on a serial port
e_grenon
I have an Agilent 34401A multimeter and I try to build a program to communicate with it in compaq visual fortran 6.Themultimeter needs to communicate with the DTR / DSR handshaking, 9600baud, parity none, 1 start bit, 2 stop bits and 8 bits data.I havecommunicateto the multimeter with a shareware like hyper terminal. It works but I have to put an line feed character at the end of each command (ex: "SYST:REM"). I have done a little program in fortran with SPORT_xx but when I try to write a command on the Com1, my program nevercompletethe instruction SPORT_WRITE_DATA(...).Maybe I need to use the SPORT_SPECIAL_FUNCT but I dont find in the help the use of this function.
this is the main part of my little program:
iresult = SPORT_CONNECT(1,DL_OUT_LF)
iresult = SPORT_SET_STATE(1,9600,0,8,2)
iresult = SPORT_WRITE_DATA(1,'SYST:REM',0) (...and the program never complete this line when I run it...)
Thank you. It's the first time that I have to communicate with a com port and I am a newbie in programming.
Eric Grenon
Read the documentation of SPORT_SET_STATE carefully. The arguments aren't what you think they are, especially regarding the stop bits.
e_grenon
Thank you for your answer...
I read the documentation:
iresult =
SPORT_SET_STATE (port [, baud] [, parity] [, dbits] [, sbits])
sbits:
(Optional; input) Integer. The stop bits for the port (0, 1, 2 = 1, 1.5, 2).
I don't understand what that mean : "(0 , 1, 2 = 1, 1.5, 2)"
what should I write if I want 2 stop bits ???
Eric Grenon
As it turns out, your call to SPORT_SET_STATE is fine. I've seen others run into trouble here. The values for the stop bits argument are: 0 means 1, 1 means 1.5, 2 means 2.
I don't know why your code doesn't work. Dealing with serial ports can be difficult. But I see that you don't check the result values - you should. They may tell you something.
jparsly
I'm suspicious about the stop bits setting. Are you sure that it is supposed to
be 2? In olden days, the baud rate was always a multiple of
(start bit + parity bit + data bits + stop bits), and you had 110 baud =
10 characters per second, 300 baud = 30 characters per second, 1200
baud = 120 characters per second. 110 baud was the odd one, using
11 bits per characters because it had 2 stop bits.The data bits +
parity bit would always add up to 8 (i.e. 8 data bits, no parity or
7 data bits, odd parity). For 9600 baud, I think I would expect the
stop bits to be 1.
e_grenon
I verified in the user manual of the multimeter and it's specified 2 stops bits:
I have an other question: should I do something to configure DTR / DSR ???
RS-232 Interface Configuration
The multimeter is configured as a DTE (Data Terminal Equipment) device. For all communications over
the
RS-232 interface, the multimeter uses two handshake lines: DTR (Data Terminal Ready) on pin 4 and DSR (Data Set Ready) on pin 6.
RS-232 Configuration Overview
Configure the
RS-232 interface using the parameters shown below.
Baud Rate: 300, 600, 1200, 2400, 4800, or 9600 baud (factory setting)
Parity and Data Bits: None / 8 data bits (factory setting)
Even / 7 data bits, or Odd / 7 data bits
Number of Start Bits: 1 bit (fixed)
Number of Stop Bits: 2 bits (fixed)
Thank you, Eric Grenon
