DLLMain in Fortran
Ilie__Daniel
Hello!
How can I use the DLLMain WinAPI in a Fortran DLL? Do I reference it from another function which is exported to the main program?
I want to check if the parent process has detached from the DLL successfully.
Thank you for any suggestions.
Daniel.
You write your own function called DllMain. This is called by Windows when the DLL is attached or detached. Such a function would start out as follows:
[fortran]function DllMain (hInstDLL, fdwReason, lpReserved)
!DEC$ ATTRIBUTES STDCALL, DECORATE, DLLEXPORT, ALIAS:"DllMain" :: DllMain
USE IFWINTY
IMPLICIT NONE
integer(BOOL) :: DllMain
integer(HANDLE), intent(IN) :: hinstDLL
integer(DWORD), intent(IN) :: fdwReason
integer(LPVOID), intent(IN) :: lpReserved[/fortran]
It would return a result of TRUE if successful or FALSE if unsuccessful. (Note that these are not the Fortran LOGICAL values .TRUE. and .FALSE.)
USE IFWINTY
IMPLICIT NONE
Ilie__Daniel
Steve,
Thank you! You're a star.
Sure, TRUE and FALSE are the ones declared in IFWINTY.
Thanks again. I can finally make sure the DLL frees the memory.
Daniel.
