29650 Discussions
Data-implied-do rejected for non-trivial subscript expression
Harald1
New Contributor II
the following code is accepted by NAG but rejected by ifort/ifx:
program p
  integer :: i(4)
  data (i(modulo(j,5)),j=1,4) /4*1/
  print *, i
end
I get:
% ifort ifort-data-implied-do.f90
ifort-data-implied-do.f90(3): error #7829: This expression cannot be evaluated.   [MODULO]
compilation aborted for ifort-data-implied-do.f90 (code 1)
NAG warns in -f2003 mode:
% nagfor ifort-data-implied-do.f90 -f2003
NAG Fortran Compiler Release 7.1(Hanzomon) Build 7101
Extension(F2008): ifort-data-implied-do.f90, line 3: Function reference in DATA-implied-DO
[NAG Fortran Compiler normal termination, 1 warning]
but stays silent with -f2008 or -f2018 and works as expected.
Note that a trivial implied do works, such as:
  data (i(j),j=1,4) /4*1/
Barbara_P_Intel
I filed a bug report on both ifx and ifort for this, CMPLRLLVM-50916.
@Harald1, I'm curious. Did you run into this issue with an application or do you just like to test the bounds of a compiler? Either way, keep them coming! These improve the Intel compiler for other developers.
jimdempseyatthecove
Try using the intrinsic function MOD.
Jim Dempsey
Steve_Lionel
MODULO is also an intrinsic function, subtly different from MOD.
jimdempseyatthecove
Yes, but using MOD, might avoid the ICE and attain the desired effect.
Jim Dempsey
Harald1
New Contributor II
Well, I also tried MOD and INT, and all are rejected (so rejects-valid, no ICE).
Which ifort version are you using?
Barbara_P_Intel
Harald1
New Contributor II
Hi Barbara,
I am performing checks on a few things that sometimes touch more recent Fortran features, and for the (usually more reliable) reference I use Intel and NAG.
From time to time there is interesting fallout, which I report here...
