Any advice on the best way to connectto a database from Fortran would be appreciated.
链接已复制
for Fortran. I am not sure the CVS repository is available again (SF has to recoverfrom ahostile intrusion
last week, but otherwise I can send you the code.
Arjen
Do I need to do anything other than find the right source code? It looks like there is a lot of other stuff that comes with it like configure.bat.
Also have you used any of the string routines. This seems like it might be useful as well?
put it all in a new version. You will have to access the CVS repository instead - or I can send them
to you
As for the string routines, yes, they are useful. I still have to stress-test them in a situation I often
use a scripting/dynamic language for, but they come in handy at times.
Arjen
Hi Arjen, I had similar problems when trying to get the ODBC sources from the link you provided. I got sidetracked onto something else but would still be interestedin having a look at your FORTRAN bindings. I have been trying to find a DLL that I could use to generate these bindings using the FORTRAN Module Wizard to so far I've been unsuccessful.
I can supply an e-mail address if you prefer not to attach it to the forum.
Many Thanks
Steve ("Dannycat")
I just tried to add a zip file to this message, but I did not succeed - the dialogue is
talking about folders to create, but not a simple file to attach.
Any idea how I should do this?
Arjen
I overlooked the fact that I can click on the folder's name - just saw "Edit" and "Delete".
The files are there now - the zip-file includes an example of how to use the interface. I did not
have a convenient makefile available, but it should be straightforward enough and otherwise
just ask.
Thanks Arjen I was able to get the files.
Unfortunately I'm new to wrapping c code with Fortran projects and have a couple questions.
Do I need a c compiler to compile the "codbc.c" code?
If not where should the c code "codbc.c"be placed in my project (I assume just a general project file rather than source file or something else)?
I'm getting the following error when compiling the test program.
I get this on the calls to odbc_exec_c.
"The CALL statement is invoking a function subprogram as a subroutine"
Do you have any ideas of what my problem may be?
Thanks again for you time.
Craig
codbc.c is a C source file and you do indeed require a C compiler that is compatible with
the Fortran compiler you use (or vice versa).
Oh darn! The interface to odbc_exec_c as defined in the routine odbc_prepare_select and others
is wrong - it should read:
interface
subroutine odbc_exec_c( ... )
end interface
I will repair it. I can create a complete library that you can just link against - that will safe you
the use of a C compiler. I will post it here (I will try this over the weekend)
Arjen
Got it - I had to make some small changes to cater for Intel Fortran (I had used CVF before and some other
compilers).
I have assumed you use Intel Fortran 11.x, then the libraries should work fine. Link with odbc32.lib as additional library. (If you use a newer version, you may need to recompile the Fortran source - that has only changed to get rid of the above mistake)
Arjen
PS I made a mistake wrt the placement of the hidden string length arguments (and no easy way to test the resulting programatm), so I updated the zip-file
Sorry for the earlierfollow-up asking for something you already provided. For some reason I didn't see the other responses.
I was able to download the libraries but am still having trouble getting it to work. My question seems pretty simple but am fairly new to Fortran and not sure how to link the other libraries.
What directory do I save the .lib and .mod files to?
Do I just add the .lib files to my project as general files and use an include statement?
Do I need to make any library property or linking property changes to my project?
How do I add odbc32.lib?
Any additional explanation of how to do this would be appreciated.
I'm getting some unrecognized token errors in codbc.lib.
Craig
No problem ;)
To answer your questions:
probably best to save the files in a separate directory in the vicinity of the rest of your
code - like: c:\myprogram\lib
Via the project properties dialogue:
- Add that directory to the INCLUDE directories for the Fortran compiler
- Add that directory to the additional library paths for the linker
- Add the libraries to the INPUT libraries for the the linker
What tokens are reported?
Arjen
Hi Craig,
sorry to respond so late. I checked: there is a reference in the file codbc.lib to a c2 DLL. It seems
to be part of the MSVC 9.0 compiler. That means I should turn the stuff into aDLL, so as to make it
more independent of the various compiler libraries.
I wil have a look next week.
Arjen
http://qtsoftware.de/vertrieb/db/fordbc_e.htm.
ForDBC comes with examples that show how to read from and to write to MS/Access database files.
Hope this helps.
Kind regards,
Jrg Kuthe
My test program calls f90_**** wrapper subroutines/functions that can be used to switch between API and F90SQL. Below is a couple of extracts from the wrapper module. Full code is in the attachment.
[bash]interfaceend interface
integer(SQLRETURN_KIND) function SQLBindCol_f(StatementHandle,ColumnNumber,TargetType, & TargetValuePtr,BufferLength,StrLen_or_Ind) !DEC$ ATTRIBUTES DEFAULT, STDCALL, DECORATE, ALIAS: 'SQLBindCol' :: SQLBindCol_f use f90SQLConstantsx integer(SQLHSTMT_KIND),intent(in) :: StatementHandle integer(SQLUSMALLINT_KIND),intent(in) :: ColumnNumber integer(SQLSMALLINT_KIND),intent(in) :: TargetType !DEC$ ATTRIBUTES REFERENCE :: TargetValuePtr integer(SQLPOINTER_KIND),intent(in) :: TargetValuePtr integer(SQLLEN_KIND),intent(in) :: BufferLength !DEC$ ATTRIBUTES REFERENCE :: StrLen_or_Ind integer(SQLLEN_KIND),intent(in) :: StrLen_or_Ind end function [/bash]
contains
logical function f90_SQLBindCol(StatementHandle,ColumnNumber,TargetType, & TargetValuePtr,BufferLength,StrLen_or_Ind) !************************************************************************** ! Binds application data buffers to columns in the result set. !************************************************************************** implicit none ! Arguments integer(SQLHSTMT_KIND),intent(in) :: StatementHandle integer(SQLUSMALLINT_KIND),intent(in) :: ColumnNumber integer(SQLSMALLINT_KIND),intent(in) :: TargetType integer(SQLPOINTER_KIND),intent(in) :: TargetValuePtr integer(SQLLEN_KIND),intent(in) :: BufferLength integer(SQLLEN_KIND),intent(in) :: StrLen_or_Ind integer(SQLRETURN_KIND) :: iRet ! Initialise iRet = 0 !DEC$ IF DEFINED (F90SQLW32) call f90SQLBindCol(StatementHandle,ColumnNumber,TargetType, & TargetValuePtr,BufferLength,StrLen_or_Ind,iRet) !DEC$ ELSE iRet = SQLBindCol_f(StatementHandle,ColumnNumber,TargetType, & TargetValuePtr,BufferLength,StrLen_or_Ind) !DEC$ ENDIF F90_SQLBindCol = SQLSAS_Chk(iRet) if(.not.SQLSAS_Chk(iRet)) then call SQL_ShowDiags(SQL_HANDLE_STMT,StatementHandle) return endif return end function end module
Any assistance in solving this would be greatly appreciated. My intention is to replace
all F90SQL dependencies from my code so that I can migrate to 64-bit configurate. All the required
functions are set up in the wrapper module.
Thanks in advance.
Steve
It is quite straightforward to access ODBC functionality from FORTRAN although it would be much easier if the Module Wizard could have been used to generate the interfaces. I was unsuccessful in finding the server application from which to Wizard could generate the code.
